Nitrous Oxide - Torquer v.2 + 100 Shot = ???
Carter01
08-21-2008, 07:06 PM
I tried searching a couple of different ways but couldn't find much info. I also thought maybe I should post this in the dyno forum but wasn't sure. Mods feel free to move if I'm in error!
Question - What type rwhp and rwt are you seeing with a 100 shot (wet)?
Car Specs -
99 LS1 Camaro
LTs, ORY, Magnaflow Catback
LS6 Intake
LS1 Motorsports Lid
Ported TB
Torquer v.2 232/234, .595/.598, 112 lsa
Currently making 392/362
Looking for "Real World" results that you guys have seen.
Thanks!!!!
firefighting1101
08-21-2008, 08:57 PM
well it depends on your kit, most of them are jetted to real world rwhp...at least i know that nitrous outlets kits are jetted to rwhp...so on a 100 shot you should see about 100hp
Mike@HSW
08-21-2008, 09:01 PM
our kits are rated at the wheel, so if you jet for a 100 shot then your going to get that. Even if a kit was rated at the crank you can figure out what jets you need to get a 100 rwhp shot.
Nauty99SS
08-21-2008, 09:08 PM
same setup , cam , lt's , only i have 78mm f.a.s.t. t/b and intake , bottle and heater are from harris , nitrous outlet conv. wet kit and 100 shot should be 100hp hope to be around 510 rwhp with the spray , mines a 99 also , we'll see in a few weeks , wiring's not done
krazy4
08-21-2008, 11:47 PM
A 100 shot should gain 100hp. It is depending on the jetting though.
My "100 shot" gained 124whp.
I consider it really a 120 shot.
Carter01
08-22-2008, 05:05 PM
Thanks for the replies! Yeah I know that a 100 shot should net a 100 but like "krazy4" stated he gained 124 whp on a 100 shot. I guess all kits perform a little different based off the way it is tuned and kit design.
How about torque increases with the 100 shot since that's something I don't currently have alot of?
Thanks!
black01_WS6
08-22-2008, 10:38 PM
a lot depends on the bottle pressure as well.
02 BLK WS6
08-23-2008, 11:28 AM
Torquer v.2 + 100 Shot = FUN
Carter01
08-26-2008, 06:20 PM
Any torque numbers out there?
GregWS6&z28
08-27-2008, 09:41 PM
dyno numbers are overrated. get some track numbers!
bad6as
08-28-2008, 06:50 PM
ill have 150 shot numbers with my torquer 2 but mine in on a 110+3
Summit2345
08-28-2008, 10:41 PM
pretty much same setup except heads, and NXL kit my car is 428 RWHP N/A, and 590RWHP with a 180 shot. The dyno owner/tuner said his dyno reads about 8-10% lower than most dynos around but I think its more realistic numbers
http://i103.photobucket.com/albums/m145/summit2345/Summit2345_2.jpg
Carter01
08-29-2008, 06:19 PM
Summit2345, is that on the stock short block?
Nice numbers by the way, any track times?
Thanks!!!
bad6as
08-29-2008, 08:50 PM
whats your race weight? not trying to be a dick, but it seams like you should be going faster and quicker. or am i wrong?
GregWS6&z28
08-30-2008, 11:00 AM
3700 raceweight, no leightweight K-member, there's a few tenths in ET with the 60' and rear suspension. need a big tire in the back with fresh meat. can probably tune 1-2 mph out of it, but I only have run the car a few times on nitrous. Is heads/cam and 150 shot slow at 10.6's?
