Putting Pacesetter LT's in?
Old 09-13-2008, 04:48 PM
sanders8800's Avatar
Default Putting Pacesetter LT's in?
How do u get the O2 sensors off old manifold? Which way should i try to put the LT's in, like from above or under?
Old 09-13-2008, 05:00 PM
lt1z28camaro's Avatar
Getting the o2's out...I used ALOT of wd40 on it. and just a wrench......you gotta man up if they're in as good as they were in mine. had someone standing on a cinder block, that was on top of the manifolds and me trying to break it lose with wrench/wd40...good luck with that, not fun haha. But it did end up working.
As for the headers. I went from bottom on passenger side and top from driver side. (mid's are what i put it, may be different with lt's..) it will also depend on how high you have it in the air.. the lt's may not be able to fit from going from the bottom due to not enought jack height.
Old 09-13-2008, 05:43 PM
SiNfulSS's Avatar
Gotta jack the car up decently high and those pacesetters will slide right in from the bottom of the car on both sides.
Old 09-13-2008, 07:30 PM
Toronto_LT1's Avatar
someones sig pic is way too big...
Old 09-13-2008, 07:36 PM
chavez885's Avatar
You have to jack the car up pretty ****** high sanders. I used 3-4 pieces of wood and a big jack, the higher you get it, the easier they slide in from the bottom.Also the o2 sensors come off, use a breaker bar and a big *** wrench. Be careful
Holy crap lol
Old 09-13-2008, 07:52 PM
James Montigny's Avatar
I've done the driver's side in/out the top, but it's much easier from the bottom.
Like they said, get it up nice and high and it'll be much easier.
Old 09-13-2008, 07:56 PM
SiNfulSS's Avatar
Holy $hit dude this is like my second post that you mentioned that WOW bored much? As I already stated in the other post I accidentally linked the wrong pic. It's fixed now so I hope you'll be able to sleep better tonight now
Old 09-13-2008, 08:07 PM
Unacceptable!!!!! Go back in time and fix it before he noticed.
Much appreciated, thanks
Old 09-13-2008, 08:15 PM
still too BIG!,resize it,NOW!
just razzin you,man. nice SS,by the way.
Old 09-13-2008, 08:24 PM
95RamAirNC's Avatar
take one side of motor lose put longtube in. tighten back then take other side lose and repeat. this was very quick process/
Old 09-13-2008, 08:50 PM
SiNfulSS's Avatar
LOL no $hit huh!
LOL aight then, never know with some of the forum people now a days, people get soooo serious over the dumbest $hit.
But anyways thanks, your LT1 is very clean, gotta be out there representing. Not many nice LT1's out there these days
Old 09-13-2008, 10:11 PM
glenb1991's Avatar
get that car as high as safely possibly........ and then some. and go in through the bottom. thats how i did mine
Old 09-13-2008, 11:34 PM
SoxXpupPeT's Avatar
alot of WD or liquid wrench and alot of heat. PS dont breath in the fumes
Old 09-14-2008, 01:29 AM
C5042081's Avatar
O2's can be a pain if rusted, I had to torch one to get it to move, theres not a lot of wrench room to work with.
i did driver side and pass side thru bottom, had to jack pass side motor mount up to clear the egr tube.
Old 09-14-2008, 09:17 AM
WD40 or liquid wrench, O2 sensor socket and a breaker bar should do it.
If they're on there so bad that you can't get em out, it might not be a bad idea to replace them anyhow.
Old 09-14-2008, 10:29 AM
StangeatinZ28's Avatar
ive always found pacesetters to fit better than any other header. they slide in perfect
Old 09-14-2008, 12:38 PM
daville_pits's Avatar
Smile
i installed my pacesetter like 2 months ago and i had to take the driver side out thru the top and the pass thru the bottom and the when installing them i actually loosened the motor mounts and i put the drivers side thru the bottom and the passenger thru the top this will let you skip some step like taking the alternater off.
and on the o2 sensors put them in a vise really tight and then soak them down with wd40 and let it sit for about 30 mins then use a end wrench with the boxed end and about a 3 foot cheater pipe and they will come out with ease no matter how long they been in there!!! GOOD LUCK
Old 09-14-2008, 02:35 PM
97lt1camaro's Avatar
Achieve 4x4 status (similar to mustangs )
Remove serp. belt, alternator, starter, dipstick tube, steering linkage.. Then giver ****.
Quick Reply: Putting Pacesetter LT's in?
