Who has broken a stock rod with ARP bolts?
Old 09-07-2003, 07:59 PM
Formerly 4mulaJoe
LS1x2's Avatar
Default Who has broken a stock rod with ARP bolts?
Who has broken a stock rod and what were the circumstances? Did you have ARP rod bolts? I'm wondering how far I could push a shortblock with stock rods/crank and forged pistons.
Old 09-07-2003, 08:40 PM
Slow Z28's Avatar
Default Re: Who has broken a stock rod with ARP bolts?
didnt Jay Johnson run 9.9x on nitrous with that combo? stock rods with arp bolts/stock crank/head/cam?
Chris
Old 09-07-2003, 10:37 PM
Formerly 4mulaJoe
LS1x2's Avatar
That would be basically my goal. Anymore info on this?
Old 09-07-2003, 10:48 PM
Shorty Director
VINCE's Avatar
Is this true. Someone ran 9.90's with stock rods and ARP Rod bolts? How much nitrous?
Old 09-07-2003, 11:01 PM
JF WS6's Avatar
Quoted from Jay in the drag racing section:
"Just a bit of info.
I am running a JE piston, stock crank and STOCK RODS!
I wish to heck that I put in a forged rod now, but
I firmly belived that I could consistantly put 550rwhp
on the stock rods if they were worked and if I could
keep the knock out of the motor.
So far my faith in the stock rod has come through.
Almost everyone said, a stock rod wouldn't last into
the low-10's. I wanted to find out(and save some
money) in this build-up.
When I put the motor together, I had a machine
shop resize and stress relieve the stock rods.
The rods were in my last motor(heads/cam/nitrous)
and they had 36k miles before I pulled that one
apart and re-used the rods in the current motor.
Stock rods ran 9.81!
Jay Johnson"
Old 09-07-2003, 11:04 PM
Cal
Cal's Avatar
I dunno, but 2001's and up are supposed to have stronger rod bolts right from the factory, although I doubt as strong as ARP's. I've heard on this board several times that going above 6700 rpm with a pre-2001 low end is walking on thin ice. So with your 2001 and ARP rod bolts you should be good for close to 7000 rpm.
Old 09-07-2003, 11:10 PM
Shorty Director
VINCE's Avatar
Jay Johnson"
Wow!!!! I guess he kept the rpm's down.. Any idea on how high he was shifting? This is really important.,.
Old 09-08-2003, 12:12 AM
annil8r's Avatar
he has a 232/236 cam on a 114 lsa so he probably wasnt shifting at that low of an rpm
Old 09-08-2003, 05:47 AM
Shorty Director
VINCE's Avatar
Same size came I have..
Old 09-08-2003, 10:35 AM
Visceral's Avatar
Ummmm... I think Jay had the ARP rod bolts. Im rather sure he's not runnign stock bolts.
I checked around before I ran my stock rods in the 388
chris
Old 09-08-2003, 10:42 AM
Vents's Avatar
fellas, Jay has a full race setup, w/ a glide, and alot of weight reduction. im sure you can pull this off, but the rods are going to let go. from what understand this was a 175 shot, but not more than that. i'd be VERY leery about doing this, especially if you were just trying to save a buck. but to each his own,
I wish to heck that I put in a forged rod now, but I firmly belived that I could consistantly put 550rwhp on the stock rods if they were worked and if I could keep the knock out of the motor.
so what happens when you cant keep the knock out?
i've pulled apart countless warranty motors from the dealership, and i cant tell you guys how many stock rods from these gen III engines i've seen snapped in half. broken right off above the big end of the rod. i.e. NOT a rod bolt failure. and this was on a STOCK un-modified motor experiencing detonation.
Old 09-08-2003, 03:47 PM
Moderator
jimmyblue's Avatar
I'm no kind of expert, but from what I've read
con rods fail in tension, not compression, and
this is RPM and rotating mass more than
HP/TQ/cylinder pressure.
Now, bent rod would be downstroke, power related.
Speed shop I used to go to had a collection of
bent aluminums from their nitro rail.
I can't see a powdered metal rod being as good
in tension as a forged steel or even ductile iron
one.
Old 09-08-2003, 06:28 PM
2001CamaroGuy's Avatar
I "WAS" going to use stock rods w/ ARP bolts in my next motor (if I did a 388) but after I talked to different people and found that I could get Eagle forged SBC rods w/ ARP bolts for ~$450 from Summit, Jegs, and others.....its just not worth the risk.....
I will put $5K in a motor....then have to start over because I wouldn't pay $500 for new rods (stocks went...)...thats not cool...
Old 09-08-2003, 07:49 PM
Cal
Cal's Avatar
They can fail either way: in tension if over reved; in compression if knock or detonation is the culprit.
