Locked PCM?
Old 09-26-2008, 07:12 PM
txturbogs's Avatar
Default Locked PCM?
My tuner told me that the PCM is locked and he cannot tune the car past minor things like a few degrees of timing and a few points of AF ratio.
He said that the previous owner or tuner locked it for some reason. He uses EFIlive to tune. Can it be unlocked??
Old 09-26-2008, 07:15 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
if the pcm is indeed locked, i dont see how he is even able to adjust the timing or air-fuel ratio
Old 09-26-2008, 07:19 PM
txturbogs's Avatar
Hmmmm, so yes, it can get locked? Basically, he said it is useless for our application since we did a H/C/intake, etc.
Old 09-26-2008, 07:21 PM
Frost's Avatar
Sounds like he is kinda confused. If it is locked, he can't tune *ANY* parameter, he can't even *VIEW* them.
Old 09-26-2008, 07:49 PM
LS1Tech Sponsor
06MonteSS's Avatar
yeah... like the others said.. if it's indeed locked, then he would not be able to do ANYTHING...
so, if he IS able to adjust the timing, or do ANYTHING at all, then your PCM is NOT locked...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 09-28-2008, 07:51 AM
Ben Diss's Avatar
Option 1: Pull the PCM and send it to the locking tuner to be unlocked.
Option 2: Buy a new PCM and flash the latest GM OS onto it.
That's it. Nothing more, nothing less. You're screwed.
Old 09-28-2008, 09:10 AM
slow's Avatar
There are other options, pull pcm, unsolder flash chip, read file, resolder flash chip back to board, find
seed/key, use efilive to unlock pcm, and then tune
But the above options are much easier
Ryan
Old 10-01-2008, 06:30 PM
txturbogs's Avatar
LOL, thanks for the advice. I ended up buying a used one. Thanks
Old 10-02-2008, 09:40 AM
wait4me's Avatar
Weird that he wouldnt be able to change ALL the tables.. A locked ecm makes it so you cant modify ANYTHING at all. It wont let you read or write to it.
Quick Reply: Locked PCM?
