Please Help!!n p0521 Code
Old 03-12-2009, 07:55 PM
Yeyo's Avatar
Default Please Help!!n p0521 Code
Hello, I have a 06 impala ss and im throwing a p0521 and I keep getting low pressure light. Do guys think its the pump or the oil pressure sensor? Thanks for the help in advanced.
Old 03-12-2009, 11:40 PM
neilownz's Avatar
hook up a pressure gauge to the sender boss
Old 03-13-2009, 01:02 AM
Yeyo's Avatar
Where's the ''sender boss''? Sorry for my ignorance. Thanks for the response
Old 03-13-2009, 11:27 AM
neilownz's Avatar
right by the throttle body where the intake neck size decreases. will need like a 0-100 psi gauge with the correct fittings.
Old 03-17-2009, 01:10 AM
Yeyo's Avatar
Ok I checked for oil pressure and im getting 55psi. So do you guys think I should replace the sensor? If not what is the next step I should take? Thanks for the help.
Old 03-17-2009, 02:45 AM
neilownz's Avatar
would be a start and should be cheaper than doing the oil pump. of course it could also be somethin like a burnt wire, fuse etc. but at least you know now that you are gettin oil pressure.
just need to troubleshoot like if it happens when dod kicks in or whatever. somethin worse may be wrong....
Old 03-17-2009, 03:48 PM
Yeyo's Avatar
I did notice that it doesnt kick in 4 mod its always in 8 mod. Thanks for the help
Old 03-17-2009, 05:50 PM
Yeyo's Avatar
Fixed!! Thank you!
Old 03-17-2009, 06:56 PM
Panther427's Avatar
What was fixed
Old 03-17-2009, 10:08 PM
Yeyo's Avatar
I just replaced the oil pressure switch and everything that was wrong with it was fixed (dod was stuck in 8cyl mode,tire pressure light and remote start works now.... all due to a simple little sensor. Hope this helps.
Old 03-17-2009, 11:19 PM
neilownz's Avatar
thats good
Old 03-18-2009, 12:29 AM
Panther427's Avatar
Good. Glad to here u deal of a car was an easy FIX. im sureyou feel better. How u likeing the new car.
Old 03-18-2009, 12:47 AM
Yeyo's Avatar
I really like the car.. I just need to get use to the front wheel drive when I hammer it...lol Over all I think its a great car.
Old 12-08-2010, 03:45 PM
CubSmurf's Avatar
@Yeyo
I know this is a major thread resurrection, but I am having the same issue with my 2006 Impala SS.
I had also diagnosed it to a bad oil pressure switch, and was wondering how easy the fix was. I am a moderately handy shade tree mechanic, is this too much for me to tackle? Or right in my 'wheel house'?
Where is the sensor located? Any help would be appreciated! Like doing these kinda jobs myself!
Old 12-08-2010, 09:15 PM
Hawkins04's Avatar
damn I just replaced mine 3 days ago
Old 12-09-2010, 07:51 AM
LS4_SS's Avatar
replaced mine last week as well
Old 12-09-2010, 08:41 AM
CubSmurf's Avatar
Did you guys do it yourself? Pain in the *** to do? Or not too bad?
Or take it somewhere? Cost estimate??
Thanks!!!
Been a great car until this, ha. Even if the MPG are no where near what they claim.lol
Old 12-09-2010, 08:49 AM
Hawkins04's Avatar
it was not bad I did it in the dark with a flash light in about 10 minutes. I could not find it anywhere so I had to buy it from the stealership for about $87.
http://i471.photobucket.com/albums/r...sureSensor.jpg
Old 12-09-2010, 08:51 AM
CubSmurf's Avatar
Thank you! THANK YOU! THANK YOU!
Old 12-09-2010, 08:56 AM
Hawkins04's Avatar
Anytime if I remember correctly you will need a 27mm deepwell socket and extension to reach it.
Quick Reply: Please Help!!n p0521 Code
