1996 LT1 issues..please help!
Old 04-01-2009, 10:49 PM
red-_-z28's Avatar
Default 1996 LT1 issues..please help!
I recently bought my 1996 Camaro z28 but there are a few problems..first off once i hit about 2500 rpm i begin to hear a light knocking sound. Im pretty sure its from the rockers..im assuming they are lose causing them to hit once i hit high rpm's. Any experience on this guys?
Also i seem to have starting issues..When engine is cold it starts up great but it seems when it get real warm its has a hard time starting. Could it be timing? or just the starter going bad?
Thank you
Old 04-02-2009, 12:11 AM
Black93_Formula's Avatar
the knocking ur hearing is probably a loose rocker or mayb more. the starting issue may be caused by ur coil getting hot when ur car warms up because its bolted to the driver side cylinder head and its gettin to hot. jus put a washer or to between it if that doesnt fix it then id check ur spark plugs n wires first before ur starter.
Old 04-02-2009, 12:18 AM
96LT1355Z28's Avatar
^^ agreed, how many miles are on it? If the previous owner replaced plugs and wires it's possible they weren't secured properly and you now have a missfire. Our wires can/ will burn and deteroriate pretty quickly if not kept away from the exhaust. My #7 cylinder was missing and I had no idea. It idled fine but it had a slight vibration at about 2500 rpm's, it didn't have a knock and if it did I wouldn't have heard it over the exhaust! I found it by checking the engine with the garage lights off, new wires and the vibration went away! Do the suggested washers to seperate the coil from the head and see if you can isolate where the noise is coming from.
Old 04-02-2009, 02:08 PM
red-_-z28's Avatar
Oh! I never thought about that! It has 120k miles and honestly I don't think the previous owner worked on his car at all. Any more info guys? BTW it's about 10-15 knocks a second once I hit 2500 rpm
Also removing the AC compressor was a bitch! Whoever has removed one did you take it out the bottom or the top?!
Old 04-02-2009, 02:22 PM
ss.slp.ls1's Avatar
If it's got a 120,000 miles and no work done. I would strongly suggest doing a FULL tune up. Get new plugs (NGK TR55's), wires (MSD 8.5mm), new coil (OEM replacement), new distributor (AC Delco or Delphi), and a new ICM (GM replacement). Perform the ICM cooling mod while you are at it.
You should also have your rockers readjusted if you think they are loose.
Get VERY familiar with this website:
http://shbox.com/1/4th_gen_tech1.html
Old 04-02-2009, 02:26 PM
djjab57's Avatar
not sure but could be hard to start because the timing is in retard because of the knock. Am i wrong on this SS or does the timing go back to 0 when the car is turned off?
Old 04-02-2009, 05:36 PM
red-_-z28's Avatar
nice website! and okay thanks guys..if anyone else knows more about this subject please post up
Old 04-02-2009, 05:39 PM
multmigs's Avatar
From the bottom I can't see for the life of me how it would come out the top unless you take the entire acces bracket off.. just need to get a bunch of socket extension, a universal swivel joint and undo the double lines on the back then the bracket that goes to the engine block and then its the 3 bolts up front....
Old 04-05-2009, 12:35 PM
red-_-z28's Avatar
Thanks guys for all the info so far!
Any more info?
Old 04-05-2009, 06:46 PM
red-_-z28's Avatar
guys...would it hurt anything if you pressure washed under the hood?
Old 04-05-2009, 06:49 PM
ss.slp.ls1's Avatar
I would advise against it. Some have done it without issue, others have had catostrophic failure.
Stick so rags, simple green, and elbow grease.
Old 04-05-2009, 07:41 PM
Originally Posted by ss.slp.ls1
i would advise against it. Some have done it without issue, others have had catostrophic failure.
x2!!:d
Old 04-05-2009, 09:22 PM
red-_-z28's Avatar
x2?
one more question...whats the best, good priced spark plugs to use on the z28?
Old 04-05-2009, 10:57 PM
ss.slp.ls1's Avatar
x2?
x2 is the same as +1. Just means he agrees with me.
NGK TR55 spark plugs. They are ~2 bucks a piece.
Old 04-05-2009, 11:07 PM
red-_-z28's Avatar
alright thanks guys
Quick Reply: 1996 LT1 issues..please help!
