Vave spring swap on-car
Old 05-24-2009, 07:42 PM
mdacton's Avatar
Default Vave spring swap on-car
What tools are you guys using?
I got all of mine on except the #8 exhaust. Its being a real bitch and I been fighting it for a hour.
it 240 on the seat and 640 open dual spring......so I need a pretty good tool
Old 05-24-2009, 09:30 PM
litch2004's Avatar
I am using the KD style tool. shbox has a picture of this tool on his website.
Old 05-24-2009, 10:01 PM
mdacton's Avatar
on a dual spring?
I was wondering if anyone has a LSM compressor if it will fit under the cowl the 800 series
Old 05-24-2009, 10:07 PM
RamAir95TA's Avatar
Use the Crane tool. Well worth it (although the holes do not fit 7/16" studs...you'll have to drill them out).
Old 05-24-2009, 10:09 PM
xx_ED_xx's Avatar
Ah changing decent valve springs on the car. Sounds like a pita to me
Old 05-24-2009, 10:59 PM
Village Troll
SS RRR's Avatar
With the engine in the car I think this is about your only option, boss.
Old 05-24-2009, 11:25 PM
litch2004's Avatar
Originally Posted by mdacton
on a dual spring?
Yes i did it with a dual spring. It was a PITA due to the inner spring wanting to decompress on a few of them. But it did work.
Old 05-25-2009, 05:58 AM
mdacton's Avatar
it won't work on this, the spring is 640# open. there is no way that tool will do that
where is the crane tool? I was looking at the LSM 800
Old 05-25-2009, 06:20 AM
mdacton's Avatar
can not find the crane tool anywhere......everyone says its N/A
this is my other option, but will it clear the cowl? http://store.summitracing.com/partde...0&autoview=sku
Old 05-25-2009, 08:56 AM
RamAir95TA's Avatar
Google is your friend.
http://performanceparts.com/part.php?partID=198936
Old 05-25-2009, 05:22 PM
mdacton's Avatar
I found a way easier way to do it...... I just used a pull bar from LSM I think but I dropped the k-member to do it. PITA but I needed it done asap. Only took about a hour
Old 05-25-2009, 09:26 PM
mhayes2344's Avatar
I was gona recommend "Tim's Tool" ...it a tool a user on here makes. He sells one for lt1's and one for ls1's...too bad you already got it too. The tool is very similar to the crane tool but it only does one spring at a time. You could've borrowed mine as I'm only ~30min away from you! Anyway congrats...dual valve springs with the heads still on the car are definitely a PITA.
Old 05-26-2009, 03:09 AM
gregrob's Avatar
I need one of these "tims tools" where do I get one?
Ill be doing patriot gold duals soon, will it work for that?
Quick Reply: Vave spring swap on-car
