went to the track yesterday
Old May 23, 2009 | 11:00 AM
shutzero's Avatar
Default went to the track yesterday
And I was kind of disappointed in my times. Last time I ran I had the mods in my sig minus the tune headers and ac delete. I ran the time in my sig. Yesterday with all the mods my best run was 13.368. Is this right?
Old May 23, 2009 | 11:04 AM
z28rob18's Avatar
i think your times are a little slow. but what was the DA and 60'?
Old May 23, 2009 | 11:08 AM
somlt1's Avatar
Originally Posted by shutzero
And I was kind of disappointed in my times. Last time I ran I had the mods in my sig minus the tune headers and ac delete. I ran the time in my sig. Yesterday with all the mods my best run was 13.37. Is this right?
Is this car a a4 or a t56? When mine was just headers loudmouth controll arms intake no tune on street tires no converter i went a best of 12.9
Old May 23, 2009 | 11:09 AM
shutzero's Avatar
I don't have the slips with me. But my 60s were 1.99 all day and the temps were 95 degrees
Old May 23, 2009 | 11:12 AM
SoxXpupPeT's Avatar
wow if your 60's weer 1.99 and you only ran a 13.38 then you need to find out whats wrong. perhaps a new tune is an order
Old May 23, 2009 | 11:15 AM
shutzero's Avatar
Its an A4
Old May 23, 2009 | 11:21 AM
shutzero's Avatar
My best 60 was 1.97 trapping 103.33 in 13.37 seconds
Old May 23, 2009 | 11:22 AM
SoxXpupPeT's Avatar
wow you should def be over 110 with that 60 foot and your mods. what are you shifting at ?
Old May 23, 2009 | 11:23 AM
Elliott's94Z's Avatar
You should def be seeing some better times then that. Have You considered putting a Stall on that thing?
Old May 23, 2009 | 11:27 AM
shutzero's Avatar
soxx, i have an auto but it shifts at 6k, and i do want to get a stall, just no money right now lol but that wouldnt really help much on the top end and top speeds woudl it
Old May 23, 2009 | 11:31 AM
shutzero's Avatar
i also just had my tune done by trifecta
Old May 23, 2009 | 11:52 AM
AChotrod's Avatar
I havent heard many great things about the trifecta tune, also it could have alot to do with the weather, and honestly your times are not that bad for your mods, but it should be a bit faster then it was b4
Old May 23, 2009 | 12:10 PM
shutzero's Avatar
so the fact that i only ran .01 faster than my last time even after headers and a tune is right?
Old May 23, 2009 | 12:22 PM
Puck's Avatar
Different day, different weather, different times. You cannot compare the two.
If you are really curious look up the tracks DA on the days of the two runs then use an online calculator to adjust them both to sea level. That would give you a good enough rough comparision to see if it is better or worst.
Old May 23, 2009 | 12:26 PM
shutzero's Avatar
well after the lts and tune my top speed was actually less yesterday than the time before
Old May 23, 2009 | 12:50 PM
AChotrod's Avatar
I would get a new tune and you said it was 95 degrees out wich isnt the best. That alone could be a couple MPH with the weather!
Ive seen other cars with a trifecta tunes that didnt add any performance
Old May 23, 2009 | 12:56 PM
SoxXpupPeT's Avatar
id say do it again on a nicer day and get another tune.
Old May 23, 2009 | 02:04 PM
shutzero's Avatar
you think a pcmforless tune would be better? or who else do you recommend for mail order? im almost at the point of just getting a cam and redo the valvetrain and having the guy that tunes cars around here do a dyno tune
Old May 23, 2009 | 02:38 PM
Hawk465's Avatar
A dyno tune will be the best, but if you go mail order Ion at Madtuner does a fantastic job.
Old May 24, 2009 | 01:45 AM
WhitePhoenix99's Avatar
What was the temp outside the day you got your previous #'s? Your et seems about right to me honestly. . . If it was a lot cooler when you went the first time not gaining any mph with your headers would make more sense.
