oil filter relocation + cooler?????
I purchased a oil filter relocation kit yesterday b/c I'm tired of having to spend $10 on brakleen to get the oil off of my headers. I'd like to get an oil cooler as well but I'm not exactly sure how I should route the lines. Do I need 2 kits to make this happen or just route one line from the relocater to the cooler and back to the bypass and call it a JOB.
I've noticed with cooler kits the bypass is thermostatically controlled, is that really necessary? It wouldn't have one if I put it together as described earlier. What have you guys done. I'm sure I'm not the only guy interested in this.
Thanks,
James
Thanks,
James
Thanks,
James
Thanks,
James
The kit does not drop your oil pressure at all. I bought all of the pieces from Canton. I can't remember if the kit uses -8 or -10 line. Either way its top quality setup, will cost you around $300, and very worth it. Changing the filter is easy and not messy.
Nick
Nick
