Turbo'd 383 build thread
Old 03-29-2010, 09:01 PM
Ralls's Avatar
Default Turbo'd 383 build thread
I'm getting close to finishing up my car so I figured I would go ahead and make a build thread. A little history... I officially put the car down back in October 2007 when I pulled the transmission to beef it up just for the heck of it. Then a couple months later I decided to pull the motor and either make it a 383 stroker or turbocharge it... I ended up doing both . So as you can see, it's been nearly 3 years since my car has ran. I have been slowly buying things one by one and now it's getting verrrry close to the end.
Run down of what is done:
Engine:
Fully forged 383 stroker
Head studs
Studded and splayed main caps
High pressure oil pump
Comp cams custom grind
Ported stock heads
LS7 lifters
1.6rr pro mags
Dual valve springs
Forced Induction:
Turbonetics T-76
Realquick's hotparts
Intercooler
Ported intake
AS&M Monoblade
Tial 50mm blow off valve
Tial 44mm wastegate
Hallman manual boost controller
2-bar map sensor
Fuel system:
Aeromotive adjustable FPR
60lb/hr fuel injectors
Walbro 255 pump with hotwire kit
Drivetrain:
Built 4l60e
Yank 3,200 stall
Midwest Chassis fab'd 9"
Strange aluminum center section
31 spline axles
3.00 gears
PST chromoly driveshaft
Misc:
ABS Delete
A/C delete
Emissions stuff deleted
Converted to vented optispark
MSD Coil
Here is the progress pictures I took over the years. I didn't take many pictures in the rebuilding process:
More to come...
Old 03-29-2010, 09:04 PM
Moderator
BizZzatch350's Avatar
Bad *** build, car looks clean too
sepno77's Avatar
Bad *** setup you got there.
Old 03-29-2010, 10:01 PM
slownova73's Avatar
subscribing
Old 03-29-2010, 10:04 PM
ThoR294's Avatar
this is my dream setup lol. TURBO 383
Old 03-29-2010, 10:44 PM
bombebomb's Avatar
Sweet set up, what kind of forged internals? I love turbo cars. Clean engine also
Old 03-30-2010, 07:44 AM
Ralls's Avatar
Thanks everyone. I'll have more pictures later today.
It's a Eagle forged rotating assembly. Dished pistons, h-beam rods, 9:1 compression.
Old 03-30-2010, 08:09 AM
registered user
ScreaminRedZ's Avatar
Looks like it's coming out great! Definitely be checking in to see how it progresses!
Old 03-30-2010, 11:27 AM
collier341's Avatar
Wow!! That engine is cleaaann. I'm diggin that monoblade too
Old 03-30-2010, 11:50 AM
ThoR294's Avatar
that midwest chassis rear is so awesome. thats on my list of future mods. cant wait for more TURBO pics
Old 03-30-2010, 06:20 PM
22lambo's Avatar
Subscribing. Nice work man!
Old 03-30-2010, 06:31 PM
AChotrod's Avatar
I approve of this build!! Great Job!
Old 03-30-2010, 06:39 PM
flyinZ's Avatar
Lookin' good Ralls! That should be a fun ride
Dumb question, but why did you choose that ratio of gearing for the 9"?
Old 03-30-2010, 06:48 PM
ebeard's Avatar
Awesome build! Are those just ported stock heads?
Old 03-30-2010, 06:50 PM
Ralls's Avatar
And the latest..
Old 03-30-2010, 06:56 PM
jaycenk's Avatar
Dude I am digin that mono blade TB. What and where did you get that? That thing is going to be a flat out bad *** monster!!! Nice build, Keep the pics rolling.
Old 03-30-2010, 07:36 PM
Ralls's Avatar
Well typically for a turbo car with an automatic you want to keep it a low gear ratio. Helps keep the turbo's spooled up during those long gears. I probably went a little lower than most do though. It's a street car and I like to keep it at low RPM's.
Yep, ported stock castings. I spent a solid 24 hours on porting those heads. Making sure each port is consistent and flawless. The valves are stock size but upgraded to Manley competition intake and severe duty exhaust.
It's made by Arizona Speed & Marine. Once you see the price you might turn around. I got it brand new for $350 and I was not going to pass that up.
Old 03-30-2010, 07:39 PM
slomarao's Avatar
AS&M makes the monoblade. You should be able to find one online.
How much power are you expecting/looking to make?? Goals?
Old 03-30-2010, 09:42 PM
kolorzcars's Avatar
im lovin this car , you gona post some nasty vids for us to drool over?
Old 03-30-2010, 09:47 PM
marc97taws6's Avatar
You should PM me with how much you've spent so far on this build.
I am very curious as I've always wanted a 383 turbo build...
I am drooling to see your results! Good, clean looking build!
Quick Reply: Turbo'd 383 build thread
