My LTX Shootout Thread
Old 08-20-2010, 09:35 AM
GIZMO's Avatar
Default My LTX Shootout Thread
Well yesterday I finally started working on my junk!
I had originally planned to build a new car for the Shootout, but I had the opportunity to buy 2010 Challenger Drag Pak #11 from Dodge which took a big bite out of my racing budget for 2010.
My first job was to install shorter front tires. Hopefully that will bring my reaction times more in line with where they need to be. After that I lowered the front end and had "Uncle" Roger do a front end alignment. Nothing trick here. Just a focus on having the car roll free.
Old 08-20-2010, 09:38 AM
GIZMO's Avatar
Step two was to put my weight bar back in (128 lbs!). The weight box is also full.
Old 08-20-2010, 09:48 AM
Racin96ss's Avatar
Nothing like getting some stuff wrapped up just before the race.
I am getting my Level 4 FLT trans put in next week!
Old 08-20-2010, 10:28 AM
am_muscl's Avatar
^^ yea no kidding, I'm swapping axles and doing a head swap this weekend and next weekend!!
That trans am looks badass!
Old 08-20-2010, 10:36 AM
GIZMO's Avatar
Wrapped up? I am just getting started!
Old 08-20-2010, 12:12 PM
Matts94Z28's Avatar
Looking good! Post some pictures of the Drag Pak if you can. Good luck!
Old 08-20-2010, 12:50 PM
A20SVT00's Avatar
motor pics would be nice
Old 08-20-2010, 02:16 PM
Racin96ss's Avatar
Yeah, but you took it home last year and I'm sure the super stock car will take it home again.
Old 08-20-2010, 04:24 PM
GIZMO's Avatar
Today I changed the oil. Four quarts Mobil 1 0-20 synthetic.
I set the fuel pressure at 50 PSI.
And installed the passenger seat to be IHRA legal.
Old 08-20-2010, 04:28 PM
GIZMO's Avatar
It's a Stocker not a Super Stocker. Huge difference. We were lucky last year. I think this year will be tougher.
Old 08-20-2010, 04:40 PM
fergymoto's Avatar
What kind of main and rod bearing clearances do you run in that thing?
Dan
Old 08-20-2010, 04:42 PM
GIZMO's Avatar
As there has been so much talk about how much money is in this motor I thought I would let you guys have a look inside!
Intake.
Exhaust runner.
Combustion chamber.
Intake runner.
Throttle body.
Maybe now some people will keep quiet when it comes to things that they know nothing about?
Old 08-20-2010, 05:07 PM
Puck's Avatar
Your camera isn't picking up the pixy dust, adjust its ISO .
Can't wait to see what you put together. Unforseen machine shop delays keep me from bringing the car, but I still might fly out there .
Old 08-20-2010, 06:31 PM
joelster's Avatar
GIZMO--let me pick your brain for a minute here........
What do you to for a slightly dragging set of front brakes like I have? Is the caliper bad and sticking? I replaced one of them but still it is difficult to turn the wheels when the car is in the air. I have heard about putting tiny springs to pry the pads apart but have not seen it myself.
What are your preferred front end alignment specs and why?
Old 08-20-2010, 06:49 PM
GIZMO's Avatar
Who's brakes do you have? I had the same problem with Aerospace calipers. I changed everything out for Strange (three cars!).
Old 08-20-2010, 06:53 PM
A20SVT00's Avatar
wow, stock
Old 08-20-2010, 07:00 PM
speed_demon24's Avatar
So you're saying if you pulled a good running stock motor out of an f-body your car would run identical times as it does with the current motor in it?
Old 08-20-2010, 07:02 PM
Village Troll
SS RRR's Avatar
Of course it would. I mean those heads are bone stock! Never bullshit a bullshitter.
Old 08-20-2010, 07:06 PM
GIZMO's Avatar
Originally Posted by A20SVT00
wow, stock
It is a 4.060 over blueprinted stock motor. The NHRA specs. can be found here...
http://www.nhra.com/competition/blueprints.aspx
It has forged pistons and rods. Both are NHRA accepted replacements (and are within the legal weight specs. The cam is stock lift, but has a lot of duration. If you look close you can see that the intake valve is "kissing" the piston at high rpm!
The intake ports flowed 205-210 CFM. The valves are stock replacements 1.94/1.50 (stainless is allowed). Any valve job is allowed. Did any of you notice the writing on the side of the heads? Is it possible that maybe someone took time to make sure that this thing is right? Please don't turn this thread into something that it wasn't intended to be.
Old 08-20-2010, 07:26 PM
Village Troll
SS RRR's Avatar
How much did it cost to have the motor built?
Quick Reply: My LTX Shootout Thread
