Worth it to remove ABS? SJM kit?
Old 08-29-2010, 07:56 PM
Rob94hawk's Avatar
Question Worth it to remove ABS? SJM kit?
As you can see from my profile pic that I have an empty engine bay. Thinking about all the things I can do while the engine is getting an overhaul I figure ridding myself of the ABS. So I've been looking at the SJM kits:
http://www.sjmmanufacturing.com/cam_brk_lt1.html
Anyone regret deleting the ABS? Anyone use the kit? Easy to do?
Thoughts? Thanx
Old 08-29-2010, 08:07 PM
trilkb's Avatar
pretty sure the only regrets people would have is locking up the tires and slamming into something
Old 08-29-2010, 08:14 PM
02sleeperz28's Avatar
I thought about it and decided it's not worth it on a daily driven vehicle in my case.
1993 z28 f1's Avatar
Hey:
Here you go some links to ponder over.
https://ls1tech.com/forums/lt1-lt4-m...bs-delete.html
Dub
Old 08-29-2010, 08:17 PM
Rob94hawk's Avatar
Been thinking along the same lines as you guys. I think about rainy, slick road situations. This is why I'm not totally sold on the idea.
Old 08-29-2010, 08:36 PM
slomarao's Avatar
I mean if you run around with slicks and skinnys I would do it. Otherwise not, its one thing to lose it on the rearend ABS with a 12 bolt but the front brakes keep them
Old 08-29-2010, 08:38 PM
Z28Roxy's Avatar
Probably not worth the trouble. non-ABS is better in some situations (deep snow), but if you even have to worry about that just pull the fuse lol.
Old 08-29-2010, 09:09 PM
hashtagBMW
Speed Density's Avatar
My cars ABS **** the bed like two weeks after buying it in 2004. It was probably sensor related but I didnt fix it. Here in Idaho we get plenty of snow and crappy weather and I never had a problem.
FWIW, I am installing the SJM kit right now. It is extrmely straight forward other than double flaring can be a pain.
Tony.
Old 08-29-2010, 11:30 PM
RamAir95TA's Avatar
I installed the SJM kit a few weeks ago and only used about half of the lines and fittings they sent. If I could do it over again, I'd definitely just piece it all together myself.
Old 08-30-2010, 08:49 AM
Badazz 97 TA's Avatar
ABS doesnt help you stop, it helps you maintain steering when in the event of wheels locking up. get rid of it!
Old 08-30-2010, 08:56 AM
wrd1972's Avatar
FWIW my ABS went stupid recently. I pulled the module and the bottom cover and found a gear had fallen off. I nut backed off and there went the gear. Replaced the gear, loctited the nut as well as the two other nuts for two other gears and it works flawless. Should have been loctited from the factory.
I would not pull ABS unless its a dedicated strip car and that is for the weight savings alone.
Old 08-30-2010, 01:50 PM
merim123's Avatar
i pulled it because I don't drive the car as much anymore and didn't want to deal with trying to fix it. I used the SJM kit, the SJM kit is engineered well, but you could create it yourself. The flaring took forever! there has to be an easier way to flare this stuff.
Also, I pulled it so I can work on the engine easier. The pedal feels a lot better. I figure with my 12bolt in back, C5 brakes up front, the ABS module wasn't designed with this stuff in mind, so figured I'd just as well take it out. YMMV>
Old 08-30-2010, 01:55 PM
RamAir95TA's Avatar
Once you use a hydraulic flaring tool you'll love flaring (believe it or not).
I also removed mine for ease of working on the engine, along with the fact that my ABS didn't work any more with the addition of the Ford 9".
Old 08-30-2010, 02:08 PM
I8ASaleen's Avatar
My ABS has never worked correctly. It's getting pulled here in a few weeks.
Old 08-30-2010, 03:17 PM
AChotrod's Avatar
Cars did just fine without it for yrs b4 it came out. Its a 20lb hunk of crap thats not needed IMO.
Old 08-30-2010, 04:27 PM
merim123's Avatar
I've seen them on some tv shows, damn, don't do enough of this to justify 300 for it.
http://www.amazon.com/MasterCool-Uni...3203602&sr=8-1
Old 08-30-2010, 04:32 PM
MasterTomos's Avatar
If it's a street driven car i'd say keep it for sure. IMO that "little extra" you get from deleting it isn't worth the streetability you'd give up. It's not like it's hidnering you from going fast.
Old 08-30-2010, 04:40 PM
airfix's Avatar
Exactly! I don't know how you other guys drive but in 5 years I was never able to lock up the tires even under har braking. Needless to say that piece of junk is long gone and I couldn't be happier.
Quick Reply: Worth it to remove ABS? SJM kit?
