throttle body hose
Old 02-17-2011, 11:09 PM
LigHtEmUp01's Avatar
Default throttle body hose
does the air pump have a hose that goes to the tb on the right side if u are looking at the front of the motor? and also i have kn cai and it looks like there should be a house on the bottom of the big plastic tube is that true?
Old 02-17-2011, 11:28 PM
RamAir95TA's Avatar
The AIR pump does not have any lines that interact with the throttle body. A line from the pump goes to each exhaust manifold, and the other line comes from the intake ducting, but nothing attaches to the TB.
Which big plastic tube are you talking about? There is a 5/8" fitting on the CAI that feeds a hose to the AIR pump, as mentioned above.
Old 02-17-2011, 11:38 PM
the big tube after the maf that dips down and then the filter goes on. and i no longer have an air pump so can i just leave it open or should i block it off. also its hard to describe with no pic but the line fitting that comes out off the throttle body on the left hand side of the car what goes there?its the one one under the throttle in the pic
Old 02-17-2011, 11:45 PM
RamAir95TA's Avatar
The bottom lines is a coolant line for the throttle body. If you've done the TB bypass you can leave it open (or preferably cap them off).
For the AIR pump you should cap everything off, both the exhaust manifolds and the port on the intake.
Old 02-17-2011, 11:52 PM
RamAir95TA's Avatar
Also, the two ports on the passenger side of the throttle body, one is for the fresh air supply hose for the PCV and the other is the discharge for the EVAP purge solenoid.
Old 02-18-2011, 12:01 AM
where does the coolant line run to?
Old 02-18-2011, 12:05 AM
RamAir95TA's Avatar
The passenger side comes from the steam tube from the back of the heads while the other line goes to the fitting directly under the radiator cap.
Old 02-18-2011, 12:08 AM
that would make sense y those 2 are left, thanks man ur a big help
Quick Reply: throttle body hose
