stuff
Old 02-18-2011, 09:34 PM
gregrob's Avatar
Default stuff
Wanted to say Corey @ Clayton is great to deal with.
Btw him and my good friend at Co Performance Unlimited I have some goodies on the way.
4.030 CP Pistons, 5cc dome, heavy wall wrist pin for nitrous
Compstar H-beam 6" rods with L19 bolt upgrade
Pro-gram engineering splayed 4 bolt mains.
Still gotta get the H bearings, oil pump / pan, cam, timing set, lifters, ATI damper etc
Shots gonna ******* rip
Old 02-19-2011, 11:45 AM
AChotrod's Avatar
Nice! What pistons did you go with and what degree splayed caps did you get? I recommend the 10* caps so you dont hit the water jackets.
Old 02-19-2011, 12:55 PM
gregrob's Avatar
They're CP pistons.
Not sure on the caps, ill have to ask corey
Old 02-19-2011, 12:59 PM
sweetbmxrider's Avatar
But I thought you knew everything? My world has just turned upside down......
Old 02-19-2011, 03:31 PM
gregrob's Avatar
Far from it. Now go away
Old 02-19-2011, 03:33 PM
LSWHO's Avatar
1. Know-it-all
2. *******
Two different things. He's 100% #2, but only 99% #1... and he's also 100% *******.
Old 02-19-2011, 03:41 PM
Matts94Z28's Avatar
Haha. If you don't have haters, you're not doing it right.
I think I am going to take the leap and get an s60 narrowed 3in, sell my prostars and QTP's and throw some RT-S'/MT's on it.
Old 02-19-2011, 03:58 PM
LSWHO's Avatar
What are you shooting for with this setup? high 10s?
Old 02-19-2011, 03:59 PM
Village Troll
SS RRR's Avatar
Spray it good and hard.
What part of that would not make your **** a turd?
Old 02-19-2011, 04:01 PM
gregrob's Avatar
At least, and that's getting down at my elevation.
Old 02-19-2011, 04:02 PM
gregrob's Avatar
250-ish
Old 02-19-2011, 04:04 PM
Matts94Z28's Avatar
The fact that my budget, stock headed 355 on a 100 pill will be faster than your 395.328678ci god build turd.
Get run over.
Old 02-19-2011, 04:05 PM
Village Troll
SS RRR's Avatar
250-ish
I thought you were only planning on running 125mph in the 1/4?
Old 02-19-2011, 04:09 PM
AChotrod's Avatar
Im sure Corey will get the right caps and pro gram caps are real nice pcs they make them for callies.
gregrob's Avatar
That was when I was using the stock short.
Then **** got real
Old 02-19-2011, 04:10 PM
gregrob's Avatar
Originally Posted by AChotrod
Im sure Corey will get the right caps.
Agreed. He was physically holding the set he's sending me and said they were what he uses for LT1s..
Old 02-19-2011, 04:13 PM
LSWHO's Avatar
That's an impressive time for sure at your elev.
AChotrod's Avatar
Ya he does a lot of LT1s he would def know. Corey is a great guy and I was going to use him for my 383, but decided to stick with Speedinc since they have never failed me, and I like to say my engine builder is the same as Z8s lol.
Old 02-19-2011, 04:17 PM
Village Troll
SS RRR's Avatar
Then **** got real
Just don't use a drag radial or you will die in a tire fire.
Get run over.
Don't cry, broseph.
Get your broke dick turd running fast and then talk. Until then, turd.
A narrowed rear to run a 100 shot? Funny.
Old 02-19-2011, 04:18 PM
gregrob's Avatar
Corey is the kind of person I would trust inside my engine. He was telling me how sometimes its needed to mix match bearings to get things PERFECT (within 1/2 a thousandth) and some other tricks a lot of builders simply won't take the time to do.
Quick Reply: stuff
