97 t/a, spins over but wont start
Old 03-29-2011, 10:25 PM
klutch-'s Avatar
Default 97 t/a, spins over but wont start
so today i had to pull my power steering pump cuz the bolts were stripped out. after putting everything back together i try to start the car and it just spins over. i hooked up a scan tool to it and reads no codes present. when i pulled the pump i disconnected the battery and altenator so i could get to the pump. any ideas?
what im thinking:
security issue? how can i reset the computer?
crank sensor? wouldnt it throw a code?
some other sensor that i may have bumped? wouldnt it throw a code as well?
any input?? ill try anything at this point. the car ran fine before i did all this.
thx.
Old 03-30-2011, 04:20 AM
klutch-'s Avatar
Anyone?
Old 03-30-2011, 04:44 AM
jester1614's Avatar
check for fuel pressure and spark first and report back, also check your fuses
Old 03-30-2011, 04:47 AM
klutch-'s Avatar
its got fuel pressure, i checked all the fuses, idk about spark yet the parts store was closed before i could go get a spark plug tester.
but ill let yall know today
Old 03-30-2011, 07:37 AM
MattSLONOMO's Avatar
just unplug a plug wire from a plug..snap the plug wire to a good used plug..
ground the sparkplug body to the body or frame.. spin it over..look for spark..
or if you have one..you can just use a timing light to make sure you have spark at every plug wire..
under these conditions it's usually something simple..
I would suspect that something was inadvertently unplugged or
maybe you forgot to hook up a ground..something like that..
that's how it usually happens ..
Old 03-30-2011, 09:06 AM
klutch-'s Avatar
i didnt remove any grounds, i may have bumped a sensor or plug some where but i over looked my work and dont see anything, im gonna go check for spark now... wish me luck
Old 03-30-2011, 09:12 AM
95 mystic ls's Avatar
Sounds like your not getting spark. Try the way Matt said, its cheaper.
Old 03-30-2011, 11:33 AM
klutch-'s Avatar
no spark, no codes, no idea....
Old 03-30-2011, 12:35 PM
SilverSS07's Avatar
If you're not getting spark check the coil. You can get a multi meter and check the ohm's on it.
Old 03-30-2011, 01:46 PM
klutch-'s Avatar
yea i gave up, ill just let the car sit there until i start the 6.0 swap. thx for the help though guys.
Quick Reply: 97 t/a, spins over but wont start
