Does this go there, if not where?
Putting back my engine, getting ready to install the opti next, but I found this part near my stack of parts (most are labeled) and it has a GM stamp on it.
If fits right in the timing cover, but from books and online search, it does not appear to actually belong there.
Anyone know where it belongs?
Yea just take the time then other wise the PCM will be triggering the CEL light for miss fires. It is used to check for miss fires from what I have been told. Also the crank hub is used to hold it flat against the Crank timing sproket. You need it in there to align and hold those tight and straight.
http://shbox.com/1/engine_front_diagram.jpg
That is an interesting alternative location.
LOL! I can relate. I bolted down my heads and forgot the thread sealant. Wasted a perfectly good set of head gaskets. At least you don't have to shell out any more $$ for your mistake like I did.
