anyone running le cam?
anyone running le cam? he specd me a 228/236 .578/.574 109 lsa.. anyone running this cam? times?
if not any his cams close to this one?
also will this cam make more power than a cc305 with bolts on and stock heads?
thanks
thanks
I'm running a Lunati 230/238 .565/.565 110+6 on his LT1 LE2 heads. His cams use more aggressive profiles than what I got. I laid down 414rwhp on a Mustang Dyno with all supporting bolt ons, .030 over bore. So pretty close to what you're asking about, maybe a tad bigger.
I'm not sure if it'll make more power than a CC305 on stock heads though.
Personally, if the heads are going to stay stock I'd lean to the smaller CC305. It should pass emissions (while the 228/236 most likely wont) if that's an issue. It matches the max flow lift range of stock LT1 heads better. The Wider LSA will give is a smoother idle (sleeper mode). And it's power band is right in the range of a stock LT1.
Plus, I like to do the smallest cam I can for a given set up. If I could've gone smaller on my set up I would've.
Le said I should get 20 to 30 hp over the cc305 cam with lazy ramps.. emissions is not a problem here. I been looking at the 280 xfi/ 07-467-8. I like a smoother idle sleeper mode..
Comps ramp rates aren't as good as Lloyds. So the valves open slower meaning less average lift. Meaning less air flow. That 280XFI will have a bit of lope at idle.
280XFI
CC305
Mine
Lloyds recommendation has faster ramps than mine which are faster than Comps.
That 228/236 cam Lloyd spec'd for you won't do that.
However, regarding power output, it will blow the CC305 into the weeds.
His 218/224 cam would outperform the CC305 AND give you the sleeper idle.
His 224/230 cam might be the happy medium for you. It will also blow the cc305 into the weeds.
http://elliottsportworks.com/?page_id=32
With stock head flow, you MUST run more overlap to get significantly more power than you have now.....and ..Overlap and "sleeper" are mutually exclusive.
The 20-30hp I was refering too was the Cam Lloyd recommended to you.
Here's my cam details ask requested.
Lunati
P/N: 20089908
Grind Number: 01-HR14-HR15
You won't find it online. Except for mine. I tried googling it already. No Bueno. (Nevermind I found it on google. LOL)
Here's the cam card.
If it wasn't for the deal I got on this cam plus that I would have to replace my brand new springs too I would have went with Lloyd's recommendation to me too. But my set up saved me $500, so I went this route. I'm still over 400rwhp on a Mustang Dyno SAE corrected. (414rwhp)
Lunati
P/N: 20089908
Better springs is a given. The question is: Do you want to be changing them every 10k miles? 227 duration / .614 lift definitely sounds like one of those categories. If you need that last 5-10 hp, then go for it. The details of the rest of the build are going to make much more difference than that 5-10 hp
