Bigger fuel pump setup needed?
With my new top end setup, I am wondering if I will need to upgrade to an even bigger fuel pump setup now? Setup in sig, 385ci, E85 fuel, AFR LT4 210 Comp, 60# Siemens injectors, turning to 7k RPM. I am currently running a single Walbro 255 but am thinking I may need to go bigger to support the top end power and E85. Any suggestions?
You may need to upgrade by adding a second pump, but I think you will be ok.
The rating figures are very subjective.
To be sure add a pump, or stay as is an monitor fuel pressure and AFR.
If you are out of pump, you will see an almost linear leaning as you hit higher Rpms.
I do not, I have the regular 255 upgrade kit from Racetronix. I may just do what BOLO suggested and go with the 340 and hotwire kit just to make sure I'm good on fueling. I already have the trap door setup so it shouldn't be to big of a deal to swap it out again.
