Gas smell and mileage
Old 06-30-2006, 06:08 PM
alconk's Avatar
Default Gas smell and mileage
I have a 94 Z that just turned 146,xxx miles and runs great but every now and then I get a strong gas smell inside the car. It seems to do it when it gets below a hlf tank of gas. I have checked for leaks but nothing and have replaced the gas cap. Also I drive on the highway mostly and can't seem to get more than 20 mpg. I hear of people getting anywhere from 22-26 mpg so what gives. The only thing I've done is LTs no cats, GMMG exhaust and a tune. The rear is stock 3.42s. It has new plugs and GM wires and a GM opti (new) So is this normal??
Old 07-02-2006, 06:43 PM
sbcgenII's Avatar
I wish i could get 20mpg! Do you happen know what you o2 voltage is when you on the highway?
Old 07-02-2006, 07:01 PM
hashtagBMW
Speed Density's Avatar
Is it leaking downt he side of the fender? My cap nozzle broke and leaked.
Old 07-02-2006, 08:12 PM
Honda Hunter's Avatar
I think it's one of your emmisions components. Maybe bad cats, air pump, egr, something along those lines.
Old 07-02-2006, 10:49 PM
LS1Silverado05's Avatar
Same boat here. Not so much when running, but after I shut it down..wow...smells of gas bad. More of a fume smell, than a "wet" gas smell, if that makes any sense. I have not found any gas leaking anywhere. Drives me nuts.
Old 07-03-2006, 08:24 AM
Alpha-Q's Avatar
I am ASSUMING: Pull vac line off fuel presure regulator at back of intake on pass side, most likely diapham is leaking and gas is getting in intake through vac line. I would scan for codes.
Old 07-07-2006, 11:28 PM
alconk's Avatar
I have no codes and no emissions. (No cats, egr, and air pump) Been all turned off. For some reason I really notice it either after I just filled it up or when it gets to a 1/4 tank. I have pulled off the pres. reg. vac line while idling and no difference. I was told though to do a smoke leak test in the tank. Possible crack somewhere in the tank filler tube??? I do have 150, xxx miles with the original pres. reg. if that makes a difference??
Old 07-08-2006, 12:35 AM
DeltaT's Avatar
Is it a California car?
Jim
Old 07-08-2006, 02:34 AM
bone324's Avatar
I've had the same problem. No codes, no issues that mechanics have been able to diagnose. It's not overpowering though.
Old 07-12-2006, 08:59 PM
alconk's Avatar
No Calif. car??
Quick Reply: Gas smell and mileage
