need estimates from others
i would like to know what i can expect from what i am doing. lt1 block i am doing the following.
full forge 383 with 10.5:1 compression ratio
lt4 hotcam
1.6 full roller rockers
ported intake to match heads
ported lt1 heads that outflow lt4 heads
what would you think i will be having at the crank
lt4 hotcam
ditch the hotcam.... that motor isnt going to make near enough power with that little *** cam... i dont understand why everybody always goes for the hotcam first... get an off the shelf or a custom grind would be alot better... from AI or LE... or Joe O..... one of those will really get you the power your looking for...
Hot cam? thats like 218* on the intake right? It will have a pretty flat torque curve, thats for sure. I think it's just a TAD on the small side It really depends what your shooting for tho. whos the head porter? that can dictate quite a bit how much power is being put down. i donno about the crank, but thru an auto, I'd say you'd be 25 hp shy of 400, at the wheels.
I know these are impalas, but it will give ya a few ideas. look at the duration class 2 tends to run, and they are in barges that have a 400lbs disadvantage. http://dan.esteban.com/impalass/Retu...electedClass=6
If youre going big, try to bypass the the Hotcam Kit.
Don't get me wrong its a great cam and very tempting in that nice little $500 package, but if I where going to be aiming at a more serious route, I would piece together my own kit, and get dual valvesprings. Not to mention new guideplates (and all the other valvetrain parts.... pro mag rockers, roller lifters, etc...)
Then you can just pick out the cam yourself. I recommend Comp Cams but alot of companies make a nice cam now. Which is good.
I like the 224/230. To give you an idea of Cam Selection, truly the most important piece of a new valvetrain, try this...
http://thunderracing.com/catalog/?ac...&vid=4&pcid=51
the only reason i am getting it is becuase i foudn a lt4 hotcam kit that has 1.6 full roller rockers, lifters, cam. for 500. i thought possibly going with a 224/224
Originally Posted by aggiez28
thats not a good deal
You get what ya pay for. And I'm not saying you have to spend an arm and a nut, but I really dont think you should skimp out on the valve train. Look at my cam (bigger than hotcam), I like it and all but it's not what I wanted. Already talked to AI about making me a custom
Looks the forum is going to have another Half assed stroked LT1, YAY!
DO NOT PUT A OFF THE SELF GRIND ON A STROKER MOTOR! I wont make good poor and it will be slow and a waste of time and money.
Yeah they make be nice with boltons, but were not talking stock cubes anymore do it right and get a custom cam grind.
Theres a guy around here with a 396 hes got a small baby cam, and running so decently ported heads. Geuss what the car on a slick cant go faster than 12.5s why?! Because the motor cant BREATH, its really pathetic to see somone spend all that money and not do it the right way.
Call JOE O and Lyd have them make you a custom cam
