what lifters?
pro magnum... those are ROCKERS? right? I thought the comp lifters were type R lifters. Oem lifters are good stuff, and aslong as the valve springs are not dual springs, or REALLY stiff, and the cam isn't over board, they should cut it.
EDIT: added the ARE NOT, instead of ARE
Originally Posted by MrCadillac
I stand corrected. Infact I don't even see type r lifters. musta replaced them as it looks like there is a milder set aswell.
They have the same part number as the "R"
We have seen a few of the newer sets fail in our area. Enough for us to shy away.
Crane makes a good quality anti-pump roller lifter made for High RPM. They cost about the same as the Morrel's and benifits can be found on there site.
I know if I type one wrong letter about them I will get hammered so check there site
IIRC, the snap clip that holds the piston inside the body fails, and lets the insides shoot all over the lifter valley. which I imagine... is NOT pretty. but that was what I heard about type r's. I donno how much design change they have. and I have heard, "good f*cking luck" getting comp to back the warrenty up when that happens. because "you odviouslys lashed the valves wrong for it to fail". but this is all stuff I have heard.
