Guys Running Cc503 Are Ya'll Running A 255lph Fuel Pump??
I was wondering if I had to run a 255lph with the CC503 because I just purchased the walbro 255lph from full throttle speed and the the racetronix wiring kit with the bgk upgrade.
hell, I hope you don't have to have a 255 walbro for a CC503! cuz I never put one in! lol
my car has a non-stock fuel pump (somebody cut the trap door out) but I think it's just a parts-store pump. feeds my 30 pounders at 78% just fine.
Almost every car Ive seen a new 255lph pump go in, the car picked up...if you plan on modding its one of the first things you should replace. Esp. with your setup heads, cam, inj, etc...really working that old fuel pump. Its a must have for modded car IMO.
Good luck!
Good luck!
I sprayed a 150 shot on the stock pump with a bigger cam. I did not have a problem with it going lean but at the same time I know I was borderlined. I put a 255lph pump in for insurance then jetted up the hit.
If you have the pump put it in but don't expeect to gain anything othe then safety for future upgrades.
You won't need it with the power levels you'll be reaching with that cam, but it's still an excellent mod nonetheless. If you decide to spray it now, you're all set. One less thing to worry about.
