Moroso CAI filter question..
You can either pull all your intake ducting to get to the filter or you can get under your car and just pull the filter from the metal plate...but it will be a PIA to get back on from the bottom. Then you spray the filter with degreaser and rinse it from the inside out. You do not want to spray from the outside in because you will imbed the dirt more. Then just let it dry completely and regrease it with the spray grease in the K&N cleaning kit.
