Im over it...
Im over it...
Put new mcleod adjust. in from friends car...better travel more pressure...
...STILL NOTHING
Put new GM Slave....NOTHING
BLEED system 10+ times for 1-3hrs 5 different ways..NOTHING
Dropped trans out of car 2 in 5 days....NOTHING
Im calling a tow truck and parking it somewhere to light on fire...PROBABLY NOT...
but really, calling a tow truck on sunday or monday to take it to a Trans specialist her on oahu, and have them worry about fixing it..im over it..
i need my car asap, and only paid bout 80-150 bucks so far about trying to fix, with a new slave and new master from friends car..but still nothing..
if anyone else wants to add something..im all ears..thanks guys..aloha
...STILL NOTHING
Did you shim the slave so that it had the right air-gap to the PP fingers? Didn't see that in your other thread.
Bleeding never takes hours. If you have a GM master and slave in and barely crack the slave (so that it's not dripping but pushing the pedal pushes fluid out,) then put a 90deg spark plug boot on it, and route a house to put the the fluid up to the reservoir, that will get rid of the air and bleed it after 5 minutes of pedal pushing, guaranteed.
im seriously calling around tomarrow..ive done everything short of buying a brand new clutch/pressure plate/flywheel. ...i really dont want to drop the trans for the 3rd time in 10 days...sorry.......but at this point ive been under my car enough for now...so i let someone else try to fix it..
but im not goin to sit there and listen to some dumbass guy try to tell me i need to replace my entire trans or need a new clutch / flywheel/ pressure plate etc..cause its all only 3 months old....thanks guys
makes me very scared to do a hydraulics upgrade on my WS6. I want to upgrade the clutch but reading all this makes me not want to and just sell the car LOL
What clutch do you have ?
I can't post it all again, lol. Long story short, my brand new flywheel came out and I put my stock 83,000 mile flywheel in and it works great now. I basically replaced everything 2 times except the clutch kit. Here's a link to the whole situation if anyone wants to read it all, lol.
https://ls1tech.com/forums/manual-tr...-3-help-3.html
you said you used a new slave but the same shim. The new slave may not have the same installed height as the old one my new slave bought from tick is almost 1/4" shorter than my original slave. just saying if it's out it only takes a min to check it.
Well...im not taking it to a shop #$@ they want 500-800 to just tell me whats wrong..ahahah..
So i just ordered a new clutch from summit...ram 900 series..stg 4.....with new pressure plate and disk...with alignment tool...goin to drop my trans for the 3rd time in 2 weeks..lol....im goin to check the shim and make sure...i replaced my slave, with the same one just newer...so the shim should be the same..right?......
im taking my flywheel off..and checking it..and probably goin to resurface it....its an aluminum..so im goin to check that to make sure of no defects..warped etc...and put new pressure plate..disk...check slave..and shim....and redo all this again....if this dont help..there will be TONS of parts for sale on here lol...wish me luck
im counting on you!!! if i cant figure this crap out soon my little lq9 swapped boosted 260z might endup in the vehicles for sale forum. what scares me about what ur about to do is that i have a brand new slave, master, clutch, and flywheel all with id say about 75 miles on them...... and they have been doing this crap since pretty much day one. really hoping you can figure it out cuz with all new parts i dont even have the slightest idea what it could be, but it seems that the only thing it could still be is the trans itself and thats $$$$ i dont have.
tomarrow...or sometime this week.when i feel like goin under my car again..to drop the trans lol...im goin to check and measure my slave using the same technique as another member did on here to see if the slave i just bought is shorter than the one i had ..i have a good feeling that is my problem, but at this point i have no idea......when i measure...im goin to see if its where that other guys "sweet spot" is..somewere between .25 and .75...so like 2.25 or so...
if its any less then 2.15 or close..than i need a bigger shim...which i can just make at my machine shop..'
can someone just reasure me? lol..thanks again
I have seen as much as 1/4" of variance on the slave/bearing compressed height as well. This is why I was asking for the measurements from Rob in his thread. It isn't that common to see this but it happens and it can certainly throw a kink into proper function.
Lazy, what clutch do you have? I don't see it mentioned in this thread.
