Pedal isn't right after manual pedal install.
Old 05-01-2010, 01:46 PM
98ZEMT's Avatar
Default Pedal isn't right after manual pedal install.
I installed my manual pedals and clutch master cylinder today in anticipation of my upcoming 6 speed swap. I got the pedals out of a 1997 v6 camaro. The master is out of a 2001 Trans Am. I drilled the holes pretty close to right. They might be off just a LITTLE bit. But they are pretty close. The problem is the clutch pedal is not even close to even with the brake pedal. I thought it would sit a little higher than the brake pedal but its a good inch or two below the brake pedal. What did I do wrong? I'm putting all this stuff in a 98 z. Thanks.
Old 05-01-2010, 03:29 PM
therobman's Avatar
its normal for it to sit higher nothing wrong
Old 05-01-2010, 03:30 PM
sxracerb25's Avatar
He said it sits an inch or two below the brake pedal.
Old 05-01-2010, 03:45 PM
Trunion King
bene's Avatar
You should have just bought a new master for your swap, it takes out the second guessing.
Old 05-01-2010, 03:55 PM
98ZEMT's Avatar
the pedal is sitting too low. Not too high. It doesn't depress the rod far enough.
Old 05-01-2010, 04:58 PM
Spartan7's Avatar
So you installed the master cylinder too? With no MC hooked up, the pedal should sit high. If it doesn't, the return spring is broken, worn, or missing.
If you do have the MC hooked up... what brand is it? Is it adjustable?
With no MC, your pedals should look like this:
Old 05-01-2010, 05:30 PM
98ZEMT's Avatar
I think everyone is getting confused. Yes I installed the master cylinder. Had to drill the holes for it. I think we got them pretty damn close but maybe off by just a little. The problem is its like the rod on the master cylinder is too short. In order to hook it to the pedal, I have to depress the pedal halfway through its travel before it gets close enough to hook. You can pull up on the clutch pedal and it WILL NOT GO ANY FURTHER TOWARDS THE STEERING COLUMN. Again, its like the rod is too short. Thinking about just getting an adjustable one and saying the hell with it. But I'd like to know if I did something wrong. Are the pedal assy. themselves adjustable? Could I have installed them wrong? Thanks again.
Old 05-01-2010, 07:14 PM
98ZEMT's Avatar
Well, I think I found my answer. I got the pedals out of a 97 v6 car. So that would mean lt1 style pedals. I thought they were all the same. But I searched and found someone with the exact same problem that swapped to the ls1 style pedals and it fixed the problem. I had no idea the pedal assy were different. Oh well. You live, you learn. Anyone need some lt1 pedals?!
Old 05-01-2010, 08:48 PM
therobman's Avatar
o i read wrong oops
Old 05-02-2010, 03:43 AM
bearcatt's Avatar
Maybe the_merv can chime in, he's real good with manual tranny conversions.
Quick Reply: Pedal isn't right after manual pedal install.
