T56 6 speed swap guys
Old 11-01-2010, 10:24 PM
1999Z28's Avatar
Default T56 6 speed swap guys
Hey I finally started on my swap. I got everything underneath wrapped up. Will be starting on the inside soon but can't find what size hole I will need to drill for the master cylinder. Anyone know for sure off hand?
Thanks
Old 11-01-2010, 10:42 PM
RedRallyeZ's Avatar
i went 2". i have the Tick MC though so it has a little larger surface to seal against the firewall. Id say that anywhere between 1 5/8" and 2" is fine.
Old 11-01-2010, 11:47 PM
therealcreeper's Avatar
yeah I went with a 2" hole as well
Old 11-01-2010, 11:51 PM
WS6SP33D's Avatar
Im starting my swap this week just trying to get everything together, anything special i will need
Old 11-02-2010, 12:43 AM
RedRallyeZ's Avatar
Nothing really exotic. Make sure you've got a 13mm swivel socket to get that bellhousing Bolt out on the a4.
Old 11-02-2010, 06:49 AM
Black02SLPSS's Avatar
Anyone get their reverse lights, cruise control and reverse lockout working? And if you did, how so?
Old 11-02-2010, 08:05 AM
Jeremy@RPMTransmissions's Avatar
I went with a 1 3/4" hole saw. You might want to look into making a reinforcement panel to go around the hole about 2". I have seen a few guys having problems with the firewall cracking after swapping. As for the lights and functions you will need to repin the harness for reverse lockout. Cruise should still work but it will not shut off when you push in on the clutch. You will have to tap the brake first.
Old 11-02-2010, 08:57 AM
WS6SP33D's Avatar
I would like to know this also ^
Old 11-02-2010, 09:11 AM
RedRallyeZ's Avatar
There is a big connector on the side of the A4 shifter. The light green and brown wires are for reverse. Run those to the connecotr on the passenger side of the trans.
you can rig them so they dont pop out, or you can get the reverse light pigtail, VSS connector, and reverse lockout connector on ebay for about $30. the very last post in the trans swap sticky has exactly what to search for on ebay, and a wealth more info.
for the reverse lockout there are a couple of ways to do it. You can go through the PCM so it activates under 3mph, youll have to read the sticky for that. OR you can wire it so the brake pedal activates the solenoid. There is a green wire and a pink wire on that pigtail. Ground the green wire (i chose the area right behind the airbag module) and run the pink wire to the blue(ish) wire on the switch on the brake pedal.
works perfectly
Old 11-02-2010, 09:48 AM
therobman's Avatar
i wired my reverse lockout to a switch my cruise doesnt work and the reverse lights wire up in 2 seconds
Quick Reply: T56 6 speed swap guys
