clutch pedal engagement question & BEWARE Monster clutches
Installed a Monster clutch stage 2? (dual friction) clutch package this weekend. What a nightmare it turned into. when I had it back together bleeding the clutch at the slave cylinder screw, the entire HOUSING of the BRAND NEW slave cylinder straight SHEARED OFF when I went ti tighten it with a normal ratchet. Had to take out the entire trans again and use the new throwout bearing on the old OEm slave cylinder/housing
I thought I could trust Monster given they're freaking expensive, its was a full kit adn everyone said good things. That said, I am happy with the clutch, but having to pull the trans back out adn reuse my old slave cylinder because a brand new part was made out of incredibly poor quality metal and sheared, I can't say I had a good experience.
So beware if you're considering them.
***Quick question: All said and done, the engagement point for my clutch now is almost all the way to the floor on the pedal, its rock solid firm, I know its bled well, is this normal to have such a low engagement point? My OEm point was mid-way in pedal travel.
LOL, Monster doesnt make the slave cylinder guy, its supposed to be a brand new GM unit. Slave cylinders are known to be hit or miss with these cars. To blame the clutch assembly for a faulty slave is like pissin in the wind.
And if you think Monster is "freakin expensive" check out some other options that easily climb over $1k for a clutch without them providing you with a slave & all the stuff you get with a Monster kit.
Sometimes you get a faulty part right off the assembly line, honestly I'm not suprised it was the slave that was the weak link. You not the first person to have a slave **** on you while being brand new, no matter what clutch it was being used with.
On the pedal if you installed the Tick Master along with the clutch its a adjustable unit & you have to set it up properly, its not a right out of the box bolt it up & start driving kind of piece. If its a stock master I'm not sure what your gonna have to do.
I think he means Slave cylinder
Sorry you had to pull the trans again,
But if anyone is responsible for the slave cylinder its GM
Of course you're the 1st on the planet that this ever had this problem too !
I'm a little off put by your comments of "beware of Monster" considering the slave isn't manufactured by us. I understand your frustration but that is a little harsh considering.
That is correct we do not make the slave cylinder. We purchase the slaves directly from the manufacturer (AP).
I apologize that this happened, the unit comes with a 12 month warranty and we'd be more than happy to get you taken care of.
One thing that concerns me is that our Level 2 hasn't had a dual friction disc in almost a year...
Regardless, give us a call and we'll get you taken care of immediately.
And you probably didn't correctly measure for the air gap during install is why your pedal grabs on the floor. Next thread will be my car wont go into gear. I have seen very satisfied Monster customers when the stuff is properly installed.
