LT1-T56 clutch
Old 09-07-2012, 10:40 PM
3.8redbird's Avatar
Default LT1-T56 clutch
I have an LT1-T56 that I am swapping into my corvette. I Just need a simple clutch to use and get better at driving.
Will a stock clutch bolt up behind a gen 1 sbc with the correct thrust bearing or will I need a special clutch?
Would be getting the whole clutch package but would like to keep a simple clutch before going to a twin disk or the like centerforce.
Old 09-07-2012, 11:13 PM
jmd
jmd's Avatar
The 93-97 LT1 T56 flywheel and clutch bolt to any 86 and newer production SBC.
If it's an 85 or older crank, you need to address the bolt pattern / balance differences; usually with an aftermarket flywheel (balanced for either 400SBC or neutral balanced and the correct 3.58" bolt pattern.)
Next time post the year of your vette and engine.
Old 09-08-2012, 08:52 AM
1bigoldman's Avatar
Like jmd said. If it's early style neutral balance you will need Centerforce part 700107. I do not know what you would need for external balance.
Old 09-08-2012, 09:31 AM
3.8redbird's Avatar
I would get a balanced fly as I have a 383 and yes it is a gen 1 sbc 2 pc rms.
Engine 1985 block 2 pc rms with a 10.5:1 383 with Dart iron eagles, HSR, and a medium comp cam. Made 408 through an auto and IRS on a happy dyno.
Old 09-08-2012, 12:38 PM
jmd
jmd's Avatar
Post
Assuming your 383 is balanced like a 400,
Centerforce has one balanced for an external balance 400 SBC. It's NOT in their catalogue or very find-able online; call them. I have installed a couple of these.
Spec has a weight plate that bolts to their neutral balance flywheel for use w/ 400 SBC.
Don't use a balance plate that bolts in between the flywheel and crank. With the Valeo pull clutch on the 93-97, it throws off the clutch fork angle and prevents the clutch from releasing properly.
Old 09-08-2012, 11:13 PM
3.8redbird's Avatar
exactly what I was looking for. thanks.
With that plate I can use a stock or similar LT1 clutch correct?
Old 09-09-2012, 12:25 AM
jmd
jmd's Avatar
Post
Welcome. The two above, yes.
Old 09-14-2012, 03:34 PM
3.8redbird's Avatar
For anyone interested or that searches:
external balance 2pc rear main seal 383/400 gen 1 fly wheel part# 700173
Quick Reply: LT1-T56 clutch
