How much should a clutch replacement job cost?
Old 10-25-2005, 01:42 PM
DF
DF's Avatar
Default How much should a clutch replacement job cost?
Im getting a quote for $900 parts and $300 for labor for a replacement for a clutch on a 2000 ss M6.
thoughts?
Old 10-25-2005, 01:59 PM
LS1TECH Sponsor
Steve Burger's Avatar
Labor sounds about right. What clutch? That will determine parts cost.
Old 10-25-2005, 02:21 PM
DF
DF's Avatar
Sorry bout that...
Im just replacing it with a stock clutch or what ever the OEM equivalent is. IM not going the MCloud route. My racing days are over and I just want reliability.
thanks
Old 10-25-2005, 02:25 PM
JoeyAnderson's Avatar
They're routing you on clutch cost. Installation even seems high to me.
I'm paying 900 for Spec 3 Clutch, Billet Steel Flywheel, Upgraded Slave and Install.
Old 10-26-2005, 02:30 AM
Robinator's Avatar
not to mention you can buy a Z06 clutch and flywheel for about $360.
Old 10-26-2005, 10:32 AM
GETGONE's Avatar
Sounds high to me. Getting the clutch in my Sonoma replaced now. New Master/slave cylinders and new clutch all AC Delco parts plus fluid change in tranny is going to be $1050 installed.
Old 10-26-2005, 11:48 PM
TroubledWine3's Avatar
$900 for stock OEM replacement parts? You can get a Textralia clutch(one of the top 2 clutches people reccommend as the BEST) package, which comes with the new slave, for $900 or so.
OEM replacement=z06 clutch. You can get the z06 clutch, new pressure plate, and new flywheel for $450. They are screwing you big time on parts and I've personally never seen an install for clutch/slave over $250.
Old 10-27-2005, 03:48 PM
02 Camaro SS's Avatar
900 is definitely too high for just the parts. I got my spec stage 3, resurfaced flywheel, and install all for $825. The clutch itself was $400. Your install price is good, but they're definitely overcharging for the parts.
Old 10-28-2005, 09:36 AM
92SilverSHO's Avatar
300 is pretty cheap for a clutch install, the south is dirt cheap for labor rates, compared to the northeast, i mean just check out the northeast sponsors and the southern sponsors.
Old 10-28-2005, 03:16 PM
Robinator's Avatar
thats cause the south gits er done!
Old 10-28-2005, 04:56 PM
Louie83's Avatar
Damn you Southies with your cheap labor and warm weather!!
Quick Reply: How much should a clutch replacement job cost?
