Polyeurathane tranny mount question
I just installed a Textralia clutch and poly tranny mount along with a tunnel brace mounted torque arm and when i slip the clutch in first gear to get going, the car will vibrate to no end, is this normal for the poly mount or is my clutch bad? if this is what happens with the poly mount, ill put the rubber back in because it feels liek the car is about to vibrate apart
Originally Posted by FSUNole17
yes it does jump around
usually from burn spots on the flywheel(from hard driving/no resurface during new clutch install.)
otherwise check bracket around the mount is tight. if it is, than its clutch related.
my .02
a poly mount will make the car sound like a helicopter when you first install it. usually they just need a few thousand miles to break in and soften up. If still no good, the tranny might be up too high and you may need to remove the preload backing plate from the mount, and possibly shim out the crossmember with washers. I did both.
