The Ram is Slipping once again, have questions.
Old 11-12-2006, 02:25 AM
The PAT WS6's Avatar
Default The Ram is Slipping once again, have questions.
Ok, i have the ram power grip clutch this is the second one i have had in the car this once is has lasted a total of 3 months and no more than 5k miles. It has never been launched out at all, it has been raced only highway. now i am experience it slipping. My old one had lasted me alot longer and went out at the track, and i sent it off and ram re-built it, and sent it back, and i reused the shim that was in there and i belive the shim is what is causing my problem i got my fly wheel resurfaced and just used a total of 1 shim to put behind the slave cylinder and i noticed the clutch felt the same as far as disengaging it engaged about and inch from the top of the pedal, which makes me think the clutch was not fully matted (engaged). In which in this case im not sure if i should of not put the shim in or added a total of 2 shims? which ever would of made the clutch engage closer to the floor would of solved the problem.
Now my question is if i get a adjustable Master Cylinder and make the clutch engage more (closer to the floor when relasing the pedal) will this make the clutch not slip any more?
or am i screwed with pulling the tranny and replacing everything. im thinking of going with the ls7/ls2 flywheel and clutch setup.
any advice/help would be greatly apprecited here guys..
thanks
Old 11-12-2006, 09:47 AM
ttt for the day
Old 11-12-2006, 10:21 PM
any help here guys?
Old 11-12-2006, 10:59 PM
INMY01TA's Avatar
You say you're not launching it so when is it slipping?
Old 11-13-2006, 08:45 AM
fifth sixth gear going about 50mph hi the gas and it revs up
Old 11-13-2006, 10:48 AM
Chilly Palmer's Avatar
Check out my thread on my install yesterday with the RAM Powergrip HD - there's a chance the shim may be causing pre-loading of the pressure plate fingers, which, if true, could cause premature slippage.
https://ls1tech.com/forums/manual-transmission/607439-need-help-getting-tranny-back.html
Old 11-13-2006, 01:30 PM
i do think that is the case, cus it will engage really high off the floor when goin back in and adding an additional shim, or just getting an adjustable master cylinder fix this problem or do i need to trash the ram and just get a ls7/ls2 flywheel setup
thanks
Old 11-13-2006, 08:29 PM
ok i need help here guys i went to drive the car to work today and it did not slip one bit????? wtf could this be? it only happened to me saturday night when i was racing and right after i got done racing.
Quick Reply: The Ram is Slipping once again, have questions.
