bleeding the clutch master cylinder?
Hi, I'm about to install a brand new GM clutch master on my 99 ls1 firebird M6. I wanted to know if i still have to bleed the clutch after i install it? The part is brand new with the fluid still inside. Please help!
I did a search and found several references to people buying masters already full of fluid.
PreBled Master
PreBled Master
Hey I've got a question not trying to hijack the thread. For the people who are installing new clutch/hydraulics... do you bench bleed it? I don't see any problem with bench bleeding since thats what these companies do. And yes I realize you can't do that with it in the car.
King of the radial tires
The clutch actuator (slave) and the line to it from the master connection are still full of old degraded clutch fluid.
It is prudent to bleed the hydraulics to ensure 100% of the fluid is clean, dry and back to nominal boiling point. Plus you want to be sure no air is in the system.
Bleed it. Cheap and easy insurance. Then keep it clean. Taking Care of Your Clutch
Ranger
Ranger
