Swapping out master..
Hey guys how ya'll been? Havent been on in awhile almost forgot how to use this site. Anyway, changing out my clutch for the 4th time in as many years and decided to go ahead and change the master as well. I searched and for some reason couldnt find Krap. Anyway can someone tell me if this is a pain? DO I need to drop my Headers as well?
thanks
thanks
Shiiiiiet..... thanks guys. I forgot all about Install U, my comp crashed and I lost all my fav sites. In the process of rebuilding. Thanks again for all the help without wise cracks. Hey wait.... thats not right.
I have only done it once and it was not too bad. If I had power tools and the deep wall socket it would of been much faster. I did it solo and took about 40 mins. Stupid star lock washer installed wrong. Took 10 mins to break that bitch out. Would be a ton easier to have someone push in the master while you pull the plunger into proper position though. Sucked for me to keep running from in the car to under the hood.
"I did it solo and took about 40 mins. Stupid star lock washer installed wrong. Took 10 mins to break that bitch out. Would be a ton easier to have someone push in the master while you pull the plunger into proper position though. Sucked for me to keep running from in the car to under the hood."
Same here, sucks by yourself, you have to be a contortionist to keep getting under the dash.
This is how I did mine by myself. It wasn't hard this way at all.
1) Put master through hole and let it rest,
2) From inside of car, pull master in and hook to the clutch pedal,
3) Twist master from inside to align holes, and then stick a 7/16" socket under the metal bracket on the floor, (this picks it up off the floor and away from the holes to allow the u-bolt to go in),
4) Put u-bolt in top first then bottom and push until it hits the metal bracket,
5) Go back inside car, hold one end of the u-bolt, take out the 7/16" socket and it will slide over the u-bolt,
6) You can do either or here: Pull the u-bolt through using the nuts or go back under the hood and push the u-bolt through then bolt it down (what I did),
7) Get friend (or wife) to help bleed it,
8) Enjoy!!!!
Took maybe 20 minutes this way for me.
8) Enjoy!!!!
I just got done changing mine. I put the u-bolt through the master right before I push it in the hole. I push the pedal down and attach the master. I pull the pedal up with the u-bolt attached and then I wiggle the u-bolt and the master until the u-bolt goes in the holes.
