What are common problems with LS motors
Old 10-15-2011, 10:59 PM
LilPhil's Avatar
Arrow What are common problems with LS motors
OK so ive been looking to maybe swap a LS motor into my 96 240sx which i use for drifting, currently have a RB25 making lil over 300whp, LS would be nice because its lighter, make more torque and HP, and will better balance
the car aswell as less things to worry about like turbos, pipes and oil lines.
My motor has been very reliable without any issues and its stock pushing 300+hp and with new turbo and fuel can easy make 500hp and be reliable.
I want a V8 and LS is easiest and cheapest but will it be worth it in long run i dont want to be fixing it all the time, i need a reliable motor, i prefer to hear from people who are from non GM cars and had or has a Japanese car or other. Lets face it Jap cars are alot more reliable and alot of die hard GM guys i know will say its very reliable anyways.
so please tell me any common issues and if they can be fixed to prevent it
common things ive herd from searching:
-oil pressure issues
-cooling
-piston slap
-bent push rods
Old 10-15-2011, 11:05 PM
chaman's Avatar
.Good luck with your search.
Coming to a GM site talking about bad reliability in GM cars, boy!
Stickies.....
Old 10-15-2011, 11:09 PM
Latch's Avatar
For performance applications, an LS1 is going to be WAY more reliable than a 4 banger. 500 hp V8 reliability > 500 hp I4 reliability.
Old 10-15-2011, 11:44 PM
Internet Mechanic
BlackScreaminMachine's Avatar
The LS motor has a well proven track record for reliability.
Period.
Old 10-16-2011, 12:18 AM
Starz T/A 17's Avatar
A RB25 is an inline 6 not a 4.
And to answer your question the LS based engines are great. If your going to be driving it hard most would recommend replacing the push rods especially if your going to upgrade the cam. But besides that there solid engines, I've had 4 different LS based cars and have never had any issues with any of them. And it seems like the people who do have issues are because they don't keep up with the regular maintenance on the cars.
But If your RB engine is running great I would just keep it. Both (RB25's and LSx's are great engines) and you really can't go wrong with either of them. So I would keep the RB unless something is wrong with it. now if you had a NA KA engine in the car I would say go for a LS swap but I wouldn't spend all the money on a swap if what you have is good. And it would probable be easier to just increase the power on your RB to 500 HP then it would be to do a LS1 swap and then add 200 HP to it.
And the whole "cars from Japan are more reliable and better then cars from America" is complete crap. Its just a false stereotype that people think is true. The fact of the matter is that a Cavalier can be just as reliable as a Civic as long as it is maintained properly.
Old 10-16-2011, 12:21 AM
garygnu's Avatar
hi-mileage and great horse power.look at the gmhitech articales about turbo 5.3.get a good boost cam.
Old 10-16-2011, 12:22 AM
senicalj4579's Avatar
1st Iv never had any issues on 3 ls1s iv had and 2nd drifting sucks. My .02
Old 10-16-2011, 01:38 AM
usafws6's Avatar
Change the oil pump, timing chain, pushrods and valve springs and youll have an extremly reliable motor.
Old 10-16-2011, 09:16 AM
LilPhil's Avatar
Well thanx for the replies, as I knew would happen u can tell the die hard GM guys, but for those with real answers thank you, I relize my motor is good and reliable but a LS would be alot better on trq and like I said no turbo and components that go along with it to worry about incase of crash or anything.
Old 10-16-2011, 09:20 AM
LilPhil's Avatar
Just tryin to see if I should go LS or keep my RB, the LS would help make the car more competitive. Just want to make sure it's a good choice Like early RB26 motors they have weak oil pumps so it's good idea to upgrade. Just want know the common things and if I go LS what should I do to it to help it last longer. usafws6 gave me some good ones thanks
Old 10-16-2011, 09:26 AM
brcampbe's Avatar
It depends how much you mod the LS motor and what your power goals are. A stock LS1 will last well into the 200K mile range with regular maintenance, many on this website have high mileage cars still going strong.
Old 10-16-2011, 09:31 AM
LilPhil's Avatar
I want 400-500 wheel HP and keep it NA, no turbo maybe a blower in future
Old 10-16-2011, 11:01 AM
ULTIMATEORANGESS's Avatar
id also recommend ARP ROD BOLTS if youre planning on high RPM driving.
Old 10-16-2011, 11:43 AM
LilPhil's Avatar
So if I decide to go LS I'm thinking maybe I'm better off building 1 from pieces instead of just getting a swap out of a Camaro
Old 10-16-2011, 11:49 AM
babbage1109's Avatar
If you get a swap take the time to tear it down replace the things that need it and do it right the first time.
Old 10-16-2011, 12:06 PM
Mookie Monee's Avatar
Stickies.....
how fast would u say a 00 trans ws6 gets to 0-60?
Old 10-16-2011, 12:23 PM
Mine is practically stock and with big wheels and low rear gear it goes 0-60 in 4.9 seconds
Old 10-16-2011, 12:57 PM
chaman's Avatar
As fast as you like. Thanks. I will be here all week!
Old 10-17-2011, 05:52 PM
1998flamedCamaro's Avatar
As fast as you can afford. Thanks. I will be here all week!
Fify...
Old 10-18-2011, 07:09 AM
fire120ball's Avatar
Agreed
Quick Reply: What are common problems with LS motors
