1998 trans am ls1 automatic help??
Old 03-10-2012, 12:57 PM
trevor98transam's Avatar
Default 1998 trans am ls1 automatic help??
i just bought a 1998 trans am with and ls1 automatic. it has an high stall kit and and heavy shift kit. im new to f-body and cars cuz im 16. is there any recalls or anything that goes wrong i need to be aware of. and what are some cheap easy ways to make it a little faster. cold air intake, headers, catback??
Old 03-10-2012, 01:04 PM
LASTOFTHEBREED02T/A's Avatar
Other than the 4l60e breaking all the time and not being up to par, dont think theres any other recalls.
The only recall i see, is a 16 yr old in a Ls1... Becarefull, this things Demand respect.
A stall is probably as far as you want to take it for now.
For Xmas, i would wish for some LT headers and Y pipe to go with it. Basic things that will improve airflow very cheap you can do now.
Lid, bellow, Filter, cut out.
Everything else will get pricey...
Old 03-10-2012, 01:08 PM
WhiteKnight '01's Avatar
I'm curious on what you mean by it breaking all the time? I've heard of FAR more problems with people replacing the tranny or clutch in the T56. The 4l60e in stock form isn't overly impressive, but it gets the job done. Mine is pushing 80,000 miles now and hasn't had a single hiccup. *knocks on wood*
Old 03-10-2012, 01:15 PM
Well yeah, look at the mods you have. Make some more power and see what happends.
It's known for them to give out in stock form after a few horses are added. Trust me I know! I blew mine couple of days after dyno.
Now Rebuilding and Throwing in a 3800Vig stall FTW
Old 03-10-2012, 01:18 PM
What he should be worried about is Stall size and if he has a trans cooler, It'll go a long way.
Old 03-10-2012, 01:22 PM
i was hoping that when they put the shift kit in that they rebuilt the tranny. the guy i bought it from said hes pretty sure they did but wasn't sure. and i saved all my money for it last summer and so taking the chance of wrecking or hurting my self is not what i want to do. and is Y-pipe better then X- pipe??
Old 03-10-2012, 01:23 PM
i think stall is 2500
Old 03-10-2012, 01:29 PM
What was the mileage and mods on your engine/tranny when it blew?
Also, have you ever done a tranny fluid swap or flush? Which would you recommend if you had?
I've heard the 4l60e is good enough to handle stock horsepower, 350, all the way up to 400. Anything past 400HP and it'll be too much for the stock tranny to handle. Is that about right?
Old 03-10-2012, 01:30 PM
Y pipe is basically a fake dual exhaust. You have two tips, but it comes from a single pipe and branches off at the rear, no real power pick up.
X pipe gives a lot more power and a lot more flow, it's the best pipes you can get.
Old 03-10-2012, 01:39 PM
Thats not really a big stall, a waste really IMO as a Mod.
Of course i had fluid flush and every precaution i knew of... 118xxx when it began slipping.
Old 03-10-2012, 01:43 PM
i think thats what it is really havnt had chance to drive it to know because of weather and having new break lines being put on now.
Old 03-10-2012, 01:48 PM
ULTIMATEORANGESS's Avatar
Smile
if your trans goes just go with a reputable builder or supplier that upgrades them.
theres many ways to add power. depends how much you want to spend and what you consider cheap. i dont consider anything worthwhile on our cars cheap but thats jmo.
Old 03-10-2012, 01:52 PM
yeah i know what you mean. ive looked up some common things but i dont know how much power they give or anything to know if there worth it.
Old 03-10-2012, 02:16 PM
stall,well worth it. LTs too. lid and catback make power to a lesser extent. its very important to find a competent tuner. this ive learned the hard way. not every tuner is good. some even suck and it can be very costly.
Old 03-10-2012, 06:32 PM
thanks man. what parts didnt do you any good?
Old 03-10-2012, 07:09 PM
01wss6's Avatar
lmao got my trans am stock this time last year when I was 16 and now have heads, cam, stall, and full exhaust. Weird guess I didn't get the heads up on that recall.
Old 03-10-2012, 07:14 PM
Lee12609's Avatar
160k on my stock 4l60e, no clue on power but i'm beyond stock power, Fast92mm intake, nick williams throttle body, cold air, flowmaster and full tune.
it shifts flawelessly whether its hot or cold even at 6300rpm (which is see's atleast once a day).
heat is what kills these things, good fluid goes a LONG way, i prefer valvoline Maxlife ATF because it handles the heat well.
Old 03-10-2012, 07:16 PM
projectX's Avatar
Well, If I were you keeping it cheaper. I would do LT headers, 3" Y-pipe, LID, Ported TB, Mail order tune to start. Start with basics then if you wanna do gears, suspension,etc later at least you got a cheap yet pretty decent amount of upgrades.
Old 03-10-2012, 07:33 PM
nice nice i have mobil 1 oil and oil filter. i havnt touched ATF since i bought it a couple month ago but hanvt really drove it.
Old 03-10-2012, 07:35 PM
do the slp lids make a good diffrience? or is a vortex or k&n cold air intake better or the same. and ported TB make a good difference
Quick Reply: 1998 trans am ls1 automatic help??
