HELP car lost power
Old 05-25-2004, 06:06 PM
q8hp's Avatar
Default HELP car lost power
i have o holden monaro with ls1 / A4 and the car lost too much power ..the car is totally stock
-what could be the reason?
-what tests to do or what to check?
thanks alot i miss my car
Old 05-25-2004, 07:09 PM
KALEL's Avatar
id start with the spark plugs. did your SES light come on? if it did i would go autozone and have them check the codes... what exactly is the car doing?
Old 05-25-2004, 08:14 PM
q8hp's Avatar
it is not the plugs ....and the car seems dead till 3K rpm
Old 05-25-2004, 08:45 PM
Racer99Bird's Avatar
what???
Old 05-25-2004, 08:52 PM
AK's WS6's Avatar
Do you have any more info to give?? Any codes, rough idle, trans related...ect. So after 3k at WOT it picks back up like normal?? How many miles do you have on it??
Old 05-25-2004, 09:04 PM
q8hp's Avatar
no codes ...idles normal...trans was rebuilt and it is fine ..i have 26K miles ?
from a dead stop the car wont go hard (it will go like i am giving it 1/2 throttle{t/c off of course}) till 3K rpm then it will do fine but not like before ..also from a rolling it does not pull as hard as before
Old 05-25-2004, 09:13 PM
Seba35LE's Avatar
It's probably the transmission. You should go to somebody and have it checked out.
Old 05-26-2004, 09:59 AM
Moderator
jimmyblue's Avatar
What is the last thing you did, before the car
"lost" power?
Old 05-27-2004, 05:52 AM
q8hp's Avatar
"lost" power?
i rebuilted the gear but it was fine till the lost of power and the gear is ok now
Old 05-27-2004, 06:24 AM
todds87ss's Avatar
I don't know if they have "Autozone" downunder...
Seems like it's trans or torque converter related, particularly since it has shown up since that work. Is it maintaining overdrive for too long (possibly an ajustment)?
Todd
