Brake lights out
Old 04-09-2007, 12:27 PM
DAn95's Avatar
Default Brake lights out
when i step on then brake just the little one on the wing lights up but if i turn on my lights or hazards those light up. do they wrk on diffrent bulbs and they are burnt out or somthing else?
Old 04-09-2007, 03:24 PM
ICEMAN 31's Avatar
when you turn on ur lights does the whole honey comb section light up when you brake. Or just like the ends of the brake light and the other half by the "TRANS AM" stay dark.
Old 04-09-2007, 03:38 PM
LS1>girlfriend's Avatar
replace the bulbs first. if that doesnt work get a wiring diagram and go hunting.
Old 04-09-2007, 05:06 PM
Closed ex-Sponsor Account
autotrix's Avatar
Check all of your fuses.
Old 04-09-2007, 05:20 PM
sreve's Avatar
very likely a bad turn signal switch. (most probably) you need to get a schematic and check it out.
Old 04-10-2007, 10:29 AM
DAn95's Avatar
changed bulbs still dont work just when i hit the brakes. the turn signals hazards and when i turn my head lights on is when the tail lights will light up its just the brakes when i hit them hit will not light up except the light on the spoiler. ill check fuses but otherwise its gotta be wring or a short right?
Old 04-10-2007, 10:39 AM
BLKWS.6's Avatar
I am betting on fuses. Those things can be a pain. THey couldnt connect a OBDII to scan my SES code (turned out to be a code for an exhaust leak-fixed) b/c a fuse was burned out. Fuse controlled the OBDII port and the cigarette lighter apparently. Check fuses.
Old 04-10-2007, 11:33 AM
Intense's Avatar
Most times the cigarette lighter blows fuses for whatever reason if you just take out the lgihter part you should be fine
Old 04-10-2007, 05:03 PM
sreve's Avatar
turn signal switch. see the pdf
File Type: pdf
Old 04-11-2007, 10:53 AM
DAn95's Avatar
thanks guys but
the turn signals work. do u mean the fuse for the turn signal switch. the #1 fuse is suposed to do the brake lights and i switched some around and i still cant get them to work.
Old 04-11-2007, 04:52 PM
sreve's Avatar
follow the wire from the brake \hazzard fuse on the schematic one way it goes directly to the center brake light. the other wire for the brake lights goes to the hazzard switch, if the hazzards are off brake lights are enabled, then it goes to the center of the turn signal switch (this is most likely where the open is) if niether turn signal is in use brake lights work with the right turn signal on it flashes and only the left and center brake light come on.
Old 04-12-2007, 01:42 PM
DAn95's Avatar
so then what do i do?
