smoke
smoke
sometimes when i start my car i get a cloud of blue smoke size of a softball does that have to do with the pcv oil consumption or is it something else i should worry about 35,000 mi (01 ws6)
Sounds like a small amount of oil leaks past the rings after it sits for a while... then burns out once you start it. Sounds like you got a little crap past your air filter at some point and scored the cylinder walls. If you're running the car without an oil filter- put one back in. Check your intake plumbing for any leaks where dirt/dust could come in.
Short of tearing the motor down and rehoning the cylinders you probably won't get rid of it... but the amount of smoke you describe shouldn't be a big deal.
Originally Posted by hardtopz28
If your talking about mine thanks for the compliment. You have a very badass car yourself.
Thanks for the compliment btw, I would tell you my mods, but then i'd have to kill you!
J/K i've got about the same mods/numbers as you.
LS1Tech Administrator
Received 1,492 Likes
Originally Posted by GregD63
It sounds like the valve stem seals. A little oil will seep by after the engine sits for a while. Its a common problem in most Chevy engines. Its nothing to worry about. The worst part is how it looks to other people.
He might be runnimg without an air filter, but I bet he is not running without an oil filter.
