Idle problem
Old 01-23-2008, 06:28 PM
zmanx's Avatar
Default Idle problem
When I put my car in park the idle goes up and down, sometimes it will settle out but other times it just keeps going.
Old 01-23-2008, 07:55 PM
sonicblue98ss's Avatar
mine did the same untill i got another pig tail for my cool temp sensor
Old 01-24-2008, 10:19 AM
BLACK2001SS's Avatar
idel re learn process ..
unhook your battery and remove pcm fuse ( cleen MAF) hook everything back up put parking brake on start car put it in drive for 5 min and in park for 5 . try it anyway its worked for me.
Old 01-24-2008, 10:25 AM
SHINER's Avatar
Check your Throttle body, if its really gunked up u will idle rough.
Old 01-24-2008, 12:53 PM
zmanx's Avatar
My throttle body is brand new.
zmanx's Avatar
Thanks I will try that.
Old 01-24-2008, 01:07 PM
zmanx's Avatar
Maybe this is a stupid question but what part of the MAF do I clean. I have an SLP. should I remove the screen?
Old 01-30-2008, 03:55 PM
Fast99408's Avatar
check all you hoses make sure there all hooked up and there are no cracks
Old 01-30-2008, 03:57 PM
Bad Blue WS6's Avatar
is it the draw from your fans kicking on/off?
Old 01-30-2008, 05:48 PM
I had a SLP MAf I have the stock in it now it might be part of your problem?
but get some CRC maf cleener and spray everything. Dont bother removing the screen but also try putting your old maf in after you cleen it and see if that helps along with the throttle relearn process. the old maf is good for 500 hp with the screen.
but also like said above check for vacume leaks also I'm just throwing ideas out thier.
Old 01-30-2008, 05:50 PM
Ls1CamaroGuy87's Avatar
Consider changing your spark plugs and wires, I did everything that people mentioned above and it didnt solve anything, it also wasnt throwing codes. I changed the plugs and wires and now it runs very smooth.....
