Dry Tuning Tip (Fuel 2-in-one Tune)
Below is the Fuel adder vs IAT that I have talked about on few occasions. What this table does is add an additional fuel multiplier on top of your WOT Power Enrichment Multiplier. So basically what you do is log your IAT n/a, then log IAT on the spray. You will see temps that are not reached n/a (read: colder) unless you live in Alaska. Now that you see your temp(s) on the spray you can add an additional fuel multiplier where needed and it will only enrich your WOT PE at the lower temps (adds to allready existing wot pe Multipier). Therefore, we now have a two tunes in one for the fuel, along with the allready known two tunes in one for timing (write up on timing in my web). This is new territory, and I don't know of any others using this for dry hits, but looks promising from my limited expermenting. FI guys use this for hotter temps. Hopefully some of you tunning gurus will take the reins on this. I will do a full write up on this at a latter date. Also am thinking about a spread sheet so you can just input your data and it will give the proper multiplier for a a/f sought. Hope this helps some of you guys wanting to run bigger dry hits and not mess up your n/a performance. Seems to work for me as I have one of the top n/a stock ETs going, and it uses the same tune as my n2o, both in sig. Now I probably don't have all of the answers, but will help if I can. The table comes zeroed out in HP Tuners, and some of the older cars you will not be able to enable, why, I don't know.
Robert
Robert
I have read posts by you & your web page concerning tuning. I am building my car little by little. I am installing a 9 inch rear right now (almost done) hopefully I'll be buying HP tuners & bigger injectors for my dry shot later this winter. I already installed the Racetronix FP kit. Hopefully you could help me with some tuning. I'll want to tune for the injectors first & my new gear ratio (4:11) I am from NW Montana.
Thanks for the info above.
Moderator
My only concern with this is that the transient thermal
response out of the IAT is going to lag the actual huff
and you will have that moment to combine excess timing
and excess air. I favor jacking the sensor with a relay &
resistor off the solenoid line, for immediacy (leading the
gas flow, even).
gas flow, even).
gas flow, even).
gas flow, even).
Robert
Robert
Originally Posted by Robert56
No problem, I'll help if I can. Upsizing your injectors is actually quite easy with HP Tuner. When your ready just ask here or in the tuning section.
Robert
Robert
gas flow, even).
gas flow, even).
This is exactly what I have talked to Robert about. I'm concerned with the time it takes the IAT to react and pull timing or add fuel.
I'd like to see a log of a dry spray run and have a look at when the maf rate picks up, does it pull spark out immidiately and does it add fuel immidiately? The safe way around this would be to just wire a resistor to activate when the n2o system is armed.
in the near furute I will be adding a 2nd dry stage and I hope by then this concern with spike u guys are talking about is taken care of either that it will not hurt anything or totally eliminated...I hope to do something like this when I'm ready
Robert
Robert
I am only going with a 125 dry shot. But I have a 2 stage controller I will set 500 rpm before the nos hits to pick the relay and trick the iat. By the time the nos hits the retard should have kicked in.
