75hp shot on moded motor
You usually want to keep injector duty cycle around 80% to be safe (that just seems to be the standard)...but you do still have room to play with before you are maxing them out...you should be fine.
Hit it once and see what it goes up to.
Robert
Restricted User
Oh pooey, BS on the IPW. If your dragracing, hang those suckers out over 100% and call it a night when see the AFR rising. I've done it with much larger shots so it has to be the way to do it! Ok, seriously though, you can def. run much higher than 80, 90 or 100% as long as it short duration and your not leaning out.
Restricted User
Seriously now, if on the track you can get away with over 100% as its only a short time, that is if all else is in good order. Some cheap alternative, find a set of Viper injectors (troll the viper boards) the tend to sell them cheap, they are 30#, but w/ LSx FP its about 34 IIRC. I ran them for some time, with a 180dry shot I was tapping on the 100%, that and a highly modded forged engine Another one, Lightning owners tend to sell their stock 42lb lime tops cheap. Ran them with over 200shots.
