do I need a bigger fuel pump?
going to be running 80hp shot (maybe 120hp later)
while getting the nitrous installed,
I am also getting my long tubes, cam, and custom tuning done
should I be safe with the stock fuel pump?
what do you guys think about the Walbro 255 lph fuel pump for GTO
thanks in advance guys,
Russ
Also, I think you'll need injectors before you need a fuel pump. In case you want to go more HP down the road, buy 42 or 60 lbs injectors and have the tuner tune them in verses waiting, then having to get a re-tune down the road.
With my current mods, my stock injectors are running at 79% at WOT around 5k RPMs. I've heard that ideally, you should keep them under 80%. I can't imagine that with your current/future setup, you'll be pushing those things to the limit if not beyond.
he really wants me to up the jets on teh No2
now I need him to get me a new clutch (to handle the power)
With the size shot you are running you should be fine with your new fuel pump. However when you tune watch for a lean spike. If there is one you will need to get the fuel accumulater.
Dave
Dave
still?
even with only the 120hp shot?
Dave
). If you can later, mount a front mount regulator, larger feed line, and use stock feed as a return you will benefit greatly from this mod....it can be done for about $400 and a couple hours. GLCharlie
too much fittment issues (with the ls2)
gonna sell it,
and get the nitro dave's LS2 Plate Wet Kit
just do the 100 pills.
and I found out,
the Walboro isn't a strait drop in on the GTO
I was told to get the LPE one
