Removed EGR and AIR
Removed EGR and AIR
I know the SES light is gonna come on... but will it make pcm screw with the car's performance.. like retard or something like that??? Or plain and simple just light the SES up on dash???
AIR pump fuse is removed and everything has block off plates.
Though I do hear some new whistling sound almost as if I have a access. drive s/c lol...
Also, if I run the AIR pump hose into my air lid, would it do anything if I re-insert the fuse???
Thanks in advance...
My car didnt come with egr but i removed the air and it takes a few minutes for the pcm to relearn air fuel ratio, if your worried about the light frost does the best tunes
Hey... how do you like your stranos... thinking about putting them on both my cars, but def my t/a and bilsteins on my t/a too
No issues with long tubes?
stranos are awesome, def. the only lowering spring i would buy. i have american racing headers and would recomend them if you have the money they are so much easier to install than other brands and with these there is no ground clearence issues that you would get with slp's.
