Problems with air inlet temp sensor
Old 06-20-2004, 02:15 AM
RJF
RJF's Avatar
Default Problems with air inlet temp sensor
ok dont know where to post this.Car is throwing this code after the cam install and after a tune.With the air temp sensor in the air box. says P0113 with high imput on the sensors throwing the code twice as read on my scanner I have bought 2 new sensors checked all wires and cant get rid of it could this cause the car to run bad at the strip the track times i got really stunk but I dont know what to do to fix the problem if you got any ideas please let me know
Old 06-20-2004, 12:59 PM
ataylors's Avatar
most likely its something in the tune, contact the person that did the tune for you
Old 06-20-2004, 01:27 PM
Moderator
jimmyblue's Avatar
Check that the connector hasn't had a pin push
back? Might try jumpering the connector pins w/
a resistor that's somewhere in the sane value
range (check the Helm book) and see if you are
getting a roughly-right reading off the scanner
then. If no, check that the harness is throwing
some voltage or current at it at least, down to
the sensor end. That should say whether it's a
physical or psycholgical problem.
Old 06-20-2004, 01:57 PM
Team ZR-1's Avatar
Your not posting what the IAT reports,
if it reports -38 degrees at some or all the time then there is a wiring or connector problem.
If values look somewhat normal but are much higher then what the outside air temp is then something is wrong with where aircleaner air is coming from or where IAT is located.
Also look to see what ECT water temp is reading.
Old 06-20-2004, 08:30 PM
RJF
RJF's Avatar
well im not forsure what the reports are all i have is a code scanner what program will i need to be able to check this and monitor the engine im done with it going to buy a lap top and a program to keep an eye on things if you guys could give me the info on what program i should get where to get it and what laptop spec need to be im going to buy my own stuff thanks
Old 06-20-2004, 09:56 PM
Team ZR-1's Avatar
As to laptop, minimum I would use for a PCM scanner
Windows 98, NT, ME XP or 2000
Pentium 166 MHz or greater or 100% compatible computer
32 MB RAM ( if using Win98)
Large capacity hard disk drive
One free serial communication port,
(best case is it has a 9 pin serial comm port rather then USB.)
CD-ROM Drive
As to the PCM scanner I prefer the Ease GM Enhanced OBD-II scanner, I have used it for over 3 years on hundreds of GM cars or light trucks and it always works correctly and supports all GM's functions.
With the scanner you would instantly know what your intake temps are or if something is broken.
Old 06-20-2004, 10:05 PM
RJF
RJF's Avatar
would something like auto tap or edit be what i need I want something where i can adjust things myself and be able to log data so after a run i can open the laptop up and see where it shifted and such
Old 06-20-2004, 10:12 PM
Team ZR-1's Avatar
Autotap is just a Read Only PCM scanner it is not a PCM tuning product,
to tune you would need LS1edit and it tunes but does not do PCM scanning
The Ease scanner is better then the Autotap and yes you can have the scanner recording while driving and then later replay it to see what all the engine and trannie functions were doing
Old 06-20-2004, 10:15 PM
RJF
RJF's Avatar
ok where would i go to buy on of these
