How Do You Turn Off SES Light? (problem after installing headers)
Old 09-03-2005, 10:08 PM
RrCoX22's Avatar
Default How Do You Turn Off SES Light???
Is there any way to turn off the SES light? I recently just bought some headers and installed them and all but had to cut part of my y-pipe before the cat and now the cat is not getting it's normal air flow. I know for a fact thats the problem because there was about a 2" gap between the inlet of the cat and the down pipe. It's ghetto patched up right now till I get a new y-pipe thurs. Just wondering if there is any way to turn this off or can only someone at a dealership tune it out or until I get my new y-pipe??? Thanks!!!
Old 09-03-2005, 10:33 PM
SSU's Drunk Typing Whore
Lithium's Avatar
LS1edit or HPtuners. But I would just learn to live with it though, or atleast until you get it tuned.
Old 09-03-2005, 11:20 PM
Import Patrol
CrawlinWS6's Avatar
or remove the battery cable for a few min, or shoot by your local auto zone they do it for free.
Old 09-03-2005, 11:31 PM
MetallicBluews6's Avatar
O2 simmulators!
Old 09-04-2005, 01:53 AM
blackfang's Avatar
That wont solve it as he has tampered with the emissions on the y pipe. best bet is LS1 edit and remove that code value in the ECU or a programmer.
Old 09-04-2005, 04:23 PM
99PontTA's Avatar
cut the feed wire to the light...purdy easy to do...
Old 09-04-2005, 04:33 PM
WhiteSSP's Avatar
Wire in a light switch to the light, and mount it somewhere. Flip the switch when you want it off or on.
Old 09-04-2005, 06:56 PM
blackfang's Avatar
Lets make it harder by wiring other crap to the car, when you can easily have someone with LS1 edit just remove that code from the ecu. Save all the bullshit with the jerry rigs.
Old 09-05-2005, 02:33 PM
freakynipples69's Avatar
get a tune.
Old 09-05-2005, 03:22 PM
BrandonDrecksage's Avatar
did you cut it before the first o2 sensor? or after the first o2 sensor and before the cats?
Old 09-05-2005, 03:30 PM
SlowTA's Avatar
autozone won't delete codes, just read them
Old 09-05-2005, 04:11 PM
KrazyDan's Avatar
when i lived in california, they deleted codes. I moved to San Antonio a couple months ago and threw a code, wentr to autozone and they told me they are not aloud to delete them????
Old 09-05-2005, 04:17 PM
Lithium's Avatar
Whenever I got to autozone I just give them my liscense and they give me the actron scanner. Then I just go to my car and delete away.
Old 09-05-2005, 07:39 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
You're stuck with the SES unless you
Fix the problem or
Tune it out or
Install O2 Simulator for that post cat O2 sensor.
Old 09-06-2005, 12:11 AM
RrCoX22's Avatar
So when I put my new catted y on should that be enough for it to tune out or would I still have to get a type of computer to tune it out.
Old 09-06-2005, 12:33 AM
Wikked00Hawk516's Avatar
Since he's addressing an issue i was going to bring up I have slp's LT's and the loudmouth on my firehawk but still have the cats. if i remove the cats and put in 02 simms will it still throw an ses or do the simms trick the ecu into thinking everythings normal?
Old 09-07-2005, 11:16 AM
LS12SEC's Avatar
Turn key over half way so power is on but not started. Pop the hood. Remove fuse cover. Pull out PCM Bat and PCM IGN. Leave out for 5 minutes. Romove key. Put both fuses back in. Start car and light is gone.
