insufficient switching 02sensor
Old 05-23-2006, 05:46 PM
supersteve7's Avatar
Default insufficient switching 02sensor
insufficient switching 02sensor... whats this exactly mean?
Old 05-23-2006, 06:54 PM
Moderator
jimmyblue's Avatar
Most often means, too cold to work right at idle after
you put headers.
Old 05-23-2006, 08:12 PM
so what do I do to fix it?
Old 05-23-2006, 09:07 PM
2K2WS6TA's Avatar
Replace with bosch 13111
Old 05-23-2006, 09:17 PM
oange ss's Avatar
could be runnin too rich or too lean
Old 05-24-2006, 09:10 AM
ringram's Avatar
Or tune open loop and toss the o2's for ever.
Old 05-24-2006, 10:35 AM
GuitsBoy's Avatar
After a dozen and a half oxygen sensors lost to this error, I finally went openloop. I do however run a wideband to keep an eye on things.
Old 05-24-2006, 01:31 PM
ZL1Killa's Avatar
i switched to the exact corvette rear oxygen sensors, still got the problem. happens about 40minutes after running around.
I have stainless steel headers, so holding heat is problem. I'm about to throw the stock ones back on and see about them
Old 05-24-2006, 01:34 PM
ZL1Killa's Avatar
are these better than the stock o2's also? I even had the problem with the stock 02's....not often but it did happen.
Old 05-24-2006, 03:00 PM
Billiumss's Avatar
Corvette O2's in a F-Body are known to cause switching problems, seen it myself.
Old 05-24-2006, 11:28 PM
Moderator
jimmyblue's Avatar
All the 'vette sensors have going for them is a somewhat
higher heater wattage. Other than that, it's the same.
So if a few more watts isn't enough to get you lit up,
too bad, get code. Kill code. I got this on mine with the
Denso 'vette rears but it hasn't affected anything about
idle or other fuel trimming so far. It's just the first warning
that stuff is marginal as far as closed loop feedback.
Old 05-25-2006, 12:25 AM
ZL1Killa's Avatar
so either trash the o2's or try to header wrap or somehow hold heat in the exhaust more(a lot more, lol)
Old 05-25-2006, 08:38 AM
SideStep's Avatar
Old 05-25-2006, 01:08 PM
ZL1Killa's Avatar
any info on this?
My car had the headers on it and the stock o2's for at least 5k miles, no problems.
now the car with the stock o2's only did the insufficient switching very seldom
the corvette rear o2s seem to do it VERY OFTEN, so why would they have better heaters in them?
