inspection help
Old 08-14-2006, 04:01 PM
Silver Bullet 8150's Avatar
Default inspection help
i am trying to get my car inspected and i have no cats on my car (mods in sig) i had the car tuned at ECS and when i get a car wash i get a check engine light for bank 1 something and i think its cause i have the o2 sims disconnected and hanging under the car. i cleared it with my buddies scanner. i went to a guy the other day and plugged in the obd2 for inspection and said its reading not connected for the oxygen sensor???? im assuming its the os sims. what do i need to do to pass for the computer????any ideas. thanks guys
Old 08-14-2006, 04:08 PM
ZL1Killa's Avatar
I think your problem is you need to check all your wires and re-connect what is unconnected, when your guys tuned out your rear 02's you shouldn't have to worry about them ever again. you need to determine EXACTLY what your BANK 1 SOMETHING is before just trying to pass inspection and have your tuner re-check your car
look no further. let me know if it works, as I'm going to go test it here soon. but since you are going right now
https://ls1tech.com/forums/showthrea...64#post5354764
Old 08-14-2006, 04:11 PM
2001NBMZ28's Avatar
Was it a post cat code? Shouldn't be a problem it they were tuned out.
Old 08-14-2006, 04:43 PM
sunsetorangessls1's Avatar
Need to post code, I passed inspection with pacesetter lt's, ory, and countless other issues. They overlooked everything but i was throwing a Hidden code. Kept sayin my 02 sensor heater wasnt ready and catalyst wasnt ready. So i drove the car for about ten mins and all was well.
J
Old 08-14-2006, 05:20 PM
J
yup thats the same thing the guy told be about the heater wasnt ready.....i was like ummm ok.....
Old 08-14-2006, 05:38 PM
P0141 "O2S Heater Performance Bank 1 Sensor 2" No MIL
if im not mistaken this is the code im getting. im trying to get it again to see if it thats one. if thats the code what should be done???????????
Old 08-14-2006, 07:17 PM
ZL1Killa's Avatar
turn it off....
you can pass inspection that way
Old 08-14-2006, 07:26 PM
Originally Posted by ZL1Killa
turn it off....
ok how do i do that????tunning?
Old 08-14-2006, 09:01 PM
ZL1Killa's Avatar
yeh get a tuning shop to do it or do it yourself if you have HPTuners or EFI LIVE or some tuning program that can turn off codes
