catalyst not tripping to "ready" for emissions test
Old Aug 14, 2006 | 12:47 PM
Cam02ss's Avatar
Default catalyst not tripping to "ready" for emissions test
is anyone here from pa that could give me a hand? my catalyst ready cycle won't trip for the emissions test and i was told to have the heaters turned back on but to leave the sensors off..does this make any sence? i have a t rex cam and its a pain in the neck trying to keep the SES light off so we do have a bunch of things turned off. if we do turn the heaters back on will that cause other codes to throw?
Old Aug 14, 2006 | 01:17 PM
ZL1Killa's Avatar
turn all of that off on the DTC's and the MIL status, then your readiness tests will be ready instantly.
turn off your fuel trim, catalyst...etc if its got to do with emissions cut it off. someone up here knows exactly what they are, i'm on my desktop right now. I can post back with what to turn off to pass later when i get on my laptop
Old Aug 14, 2006 | 02:44 PM
Cam02ss's Avatar
alright thanks man, greatly appriciated
Old Aug 14, 2006 | 04:06 PM
ZL1Killa's Avatar
i'm going to post it and I want to thank WS6FirebirdTA00 for his help in sorting all this out, as the previous post(s) that I asked/saw did not include everything to pass. Hope this comes out right, if it doesn't then it is an attachment.
THESE ARE THE DTC's to get cutoff. **Some may already be turned off for certain cars, this is not a tune to drive around in, as if you car decides to set codes and go OL or do whatever it may, you will NOT know it.
P0131 "O2S Circuit Low Voltage Bank 1 Sensor 1" X: Not Reported
P0132 "O2S Circuit High Voltage Bank 1 Sensor 1" X: Not Reported
P0133 "O2S Slow Response Bank 1 Sensor 1" X: Not Reported
P0134 "O2S Circuit Insufficient Activity Bank 1 Sensor 1" X: Not Reported
P0135 "O2S Heater Performance Bank 1 Sensor 1" X: Not Reported
P0137 "O2S Circuit Low Voltage Bank 1 Sensor 2" X: Not Reported
P0138 "O2S Circuit High Voltage Bank 1 Sensor 2" X: Not Reported
P0140 "O2S Circuit Insufficient Activity Bank 1 Sensor 2" X: Not Reported
P0141 "O2S Heater Performance Bank 1 Sensor 2" X: Not Reported
P0151 "O2S Circuit Low Voltage Bank 2 Sensor 1" X: Not Reported
P0152 "O2S Circuit High Voltage Bank 2 Sensor 1" X: Not Reported
P0153 "O2S Slow Response Bank 2 Sensor 1" X: Not Reported
P0154 "O2S Circuit Insufficient Activity Bank 2 Sensor 1" X: Not Reported
P0155 "O2S Heater Performance Bank 2 Sensor 1" X: Not Reported
P0157 "O2S Circuit Low Voltage Bank 2 Sensor 2" X: Not Reported
P0158 "O2S Circuit High Voltage Bank 2 Sensor 2" X: Not Reported
P0160 "O2S Circuit Insufficient Activity Bank 2 Sensor 2" X: Not Reported
P0161 "O2S Heater Performance Bank 2 Sensor 2" X: Not Reported
above is all the 02 heater stuff that you need to cutoff.
P0171 "Fuel Trim System Lean Bank 1" X: Not Reported
P0172 "Fuel Trim System Rich Bank 1" X: Not Reported
P0174 "Fuel Trim System Lean Bank 2" X: Not Reported
P0175 "Fuel Trim System Rich Bank 2" X: Not Reported
P0400 "Exhaust Gas Recirculation (EGR) System Performance" X: Not Reported
P0401 "Exhaust Gas Recirculation (EGR) Flow Insufficient" X: Not Reported
P0402 "Exhaust Gas Recirculation (EGR) Flow Excessive" X: Not Reported
P0404 "Exhaust Gas Recirculation (EGR) Open Position Performance" X: Not Reported
P0405 "Exhaust Gas Recirculation (EGR) Position Sensor A Circuit Low Voltage" X: Not Reported
P0410 "Secondary Air Injection (AIR) System" X: Not Reported
P0412 "Secondary Air Injection (AIR) Solenoid Control Circuit Bank 1" X: Not Reported
P0418 "Secondary Air Injection (AIR) Pump Control Circuit Bank 1" X: Not Reported
P0420 "Catalyst System Low Efficiency Bank 1" X: Not Reported
P0430 "Catalyst System Low Efficiency Bank 2" X: Not Reported
P1133 "O2S Insufficient Switching Bank 1 Sensor 1" X: Not Reported
P1134 "O2S Transition Time Ratio Bank 1 Sensor 1" X: Not Reported
P1153 "HO2S Insufficient Switching Bank 2 Sensor 1" X: Not Reported
P1154 "HO2S Transition Time Ratio Bank 2 Sensor 1" X: Not Reported
P1415 "Secondary Air Injection (AIR) System Bank 1" X: Not Reported
P1416 "Secondary Air Injection (AIR) System Bank 2" X: Not Reported
HERE ARE THE MIL STATUS that you must change; I'm assuming that you won't have to change the MIL status of the fuel trim system as it wasn't changed in mine. I will test this soon to make sure.
P0137 "O2S Circuit Low Voltage Bank 1 Sensor 2" No MIL
P0138 "O2S Circuit High Voltage Bank 1 Sensor 2" No MIL
P0140 "O2S Circuit Insufficient Activity Bank 1 Sensor 2" No MIL
P0141 "O2S Heater Performance Bank 1 Sensor 2" No MIL
P0157 "O2S Circuit Low Voltage Bank 2 Sensor 2" No MIL
P0158 "O2S Circuit High Voltage Bank 2 Sensor 2" No MIL
P0160 "O2S Circuit Insufficient Activity Bank 2 Sensor 2" No MIL
P0161 "O2S Heater Performance Bank 2 Sensor 2" No MIL
P0400 "Exhaust Gas Recirculation (EGR) System Performance" No MIL
P0401 "Exhaust Gas Recirculation (EGR) Flow Insufficient" No MIL
P0402 "Exhaust Gas Recirculation (EGR) Flow Excessive" No MIL
P0404 "Exhaust Gas Recirculation (EGR) Open Position Performance" No MIL
P0405 "Exhaust Gas Recirculation (EGR) Position Sensor A Circuit Low Voltage" No MIL
P0410 "Secondary Air Injection (AIR) System" No MIL
P0412 "Secondary Air Injection (AIR) Solenoid Control Circuit Bank 1" No MIL
P0418 "Secondary Air Injection (AIR) Pump Control Circuit Bank 1" No MIL
P0420 "Catalyst System Low Efficiency Bank 1" No MIL
P0430 "Catalyst System Low Efficiency Bank 2" No MIL
LABELS Selection
Parameters Value
P1404 "Exhaust Gas Recirculation (EGR) Closed Position Performance" No MIL
P1406 "Exhaust Gas Recirculation (EGR) Position Sensor A Performance" No MIL
P1409 "Exhaust Gas Recirculation (EGR) System Performance" No MIL
P1410 "EGR Vacuum System Restriction " No MIL
P1415 "Secondary Air Injection (AIR) System Bank 1" No MIL
P1416 "Secondary Air Injection (AIR) System Bank 2" No MIL
File Type: zip
Old Aug 14, 2006 | 07:18 PM
ZL1Killa's Avatar
readiness test guys.. there it all is... and should work.
hopefully people will search for this and see it
Old Aug 15, 2006 | 10:02 AM
Cam02ss's Avatar
thanks man, though if my heaters are already off and im being told to turn them back on and put the rear sims in, could that possibly work?
Old Apr 24, 2007 | 08:13 PM
gi8e7oi825's Avatar
I've GOT to try this!
Old Apr 25, 2007 | 12:27 AM
ZL1Killa's Avatar
anyone feel free to PM me or whatever if you need help. i realize that for some reason a lot of people have issues with these readiness tests and passing emissions.... don't we all, LOL. i guess its cuz there are soooo durn many of them
