Reverse lockout wire up?
I recently converted to a M6 in a 98 T/A. Instead of having a tech 2 re-flash the PCM I just copied the differences to my existing PCM tune. Anyone know of a pin that will provide a ground for the reverse lockout solenoid? I wired it in to pin 61 I believe and with the A4 tune this is not doing anything.
That is what I did. Without doing a write entire the PCM still operates as if it were an A4. I have been advised by the HP staff not to write entire any of these files to a 98 PCM. The 98's are prone to destruction. All ineed is a pin that prvides a ground below _ mph,or when __ is present. Anything that will correspond with reverse lockout.
I don't think such a pin exists on a A4... You will have to either do an entire write or live without it. Maybe you could wire it up to a switch so you have to press a button to shift into reverse.
