got a TC lock prob. help
I have tried all I can think of with edit.. At the 3-4 shift the TC unlocks for a second, then shifts, then locks up again.. This is just cruising around. It didn't do it a while ago, now even with putting stock settings in it, still does it... Anyone, have an answer or what to check?
Re: got a TC lock prob. help
Same issue here...I remember someone asked the question a while back and got no answer (not from Ken Kelly either):
Why does pcm unlock TC during shift even though the option in Edit is set to TCC Lock during SHift = 1? (and of course all the unlock/lock values are set properly).
yes, I even set mine back real close to stock... just to see... I have messed with it all.. I tonly started doing this recently, didn't do it a while ago..
Well the easy fix, which seems to drive fine is---
to just make the 3rd gear lock up later than the 4th. so it won't lock 3rd.. no biggie drives fine.
I actually have it shift to 3rd at say 30 then 4th at 35 then lock at 38.. the mph #'s are like 5-10 higher in edit than real life.. Takes some time and trial but works well, and doesn't **** me off now. Thats all that matters to me
